Problem with getBookmarks()
Joram
Hi all,<br />
When I'm generating a report I want to write the page numbers of specific bookmarks in a separate file. This is part of my code:<br />
IRunTask runTask = engine.createRunTask(design);
runTask.setParameterValues(params);
runTask.run(REPORT_DOCUMENT);
runTask.close();
IReportDocument document = engine.openReportDocument(REPORT_DOCUMENT);
for (Object b : document.getBookmarks()) {
String bookmark = (String) b;
// write bookmark and page number to file
</pre>
Now when I have a 3-page report document, i only get 3 bookmarks ("__bookmark_1", "__bookmark_2", "__bookmark_3") but not any of the ones I set in the report design using the bookmark section in the properties view.<br />
Am I missing something?<br />
On a side note, the document objects property map contains the following values:<br />
{page hint version=4, extraction=1, BIRT ENGINE VERSION=2.6.1, BIRT ENGINE BUILD NUMBER=/C:/birt-runtime-3_7_1/ReportEngine/lib/org.eclipse.birt.runtime_3.7.1.v20110913-1734.jar}<br />
Is the BIRT ENGINE VERSION=2.6.1 correct?<br />
Your help is highly appreciated,<br />
best regards, Joram
Joram
I solved it! The problem was that my bookmark text in the report designer (which was static) didn't have " around it. In the expression builder, instead of just setting the value to: <pre class='_prettyXprint _lang-auto _linenums:0'>BookmarkA</pre> use <pre class='_prettyXprint _lang-auto _linenums:0'>"BookmarkA"</pre>
