Hey all
Has anyone ever seen a problem like this?
1) Files get deployed using workflow / filelist; transaction deployment; with do deletes switched on
2) OD (5.01 SP1on Win2K running TS5.01) connects to destination (OD 5.01 SP1 receiver Win2K IIS5.0) and creates the temporary folder
"foldername.iwnew"3) OD publishes to new temp folder then deletes all the old content from
"foldername.iwold"4) OD cant delete the folder
"foldername.iwold" so it then deletes everything from
"foldername.iwnew"5) Callback to workflow says deployment was OK
End result:
1) My files are not deployed
2) The existing folder is deleted
3) The website is broken
4) TeamSite thinks everything is OK
5)
I get angry users...........6) I redploy but the 'junk' folders sitting on the web server cannot be deleted
We have had the permissions checked and the folder in question is under the full control of the admin user which runs the OD receiver on the destination......
The really weird thing - you can clean up the mess - put all the folders back - exactly as they were - try the whole process again and hey presto -
it works first time........Am I going mad or are there others out there who would like to start a support group
Cheers
Nathan Wall
Department of Transport and Regional Services (Australia)
