Problem with fragmented wsdl schema
paul ra.
I created a web service in websphere and tried to access it from BIRT but without success. The WSDL could be read and the services were listed but the service parameters were empty.<br />
After a bit of trial and error, I found out that BIRT does not read fragmented schemas correctly.<br />
Original WSDL<br />
<?xml version="1.0" encoding="UTF-8"?><!-- Generated by JAX-WS RI at http://jax-ws.dev.java.net. RI's version is JAX-WS RI 2.1.6 in JDK 6. --><definitions name="QueryService" targetNamespace="http://ws/" xmlns="http://schemas.xmlsoap.org/wsdl/" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:tns="http://ws/" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<types>
<xsd:schema>
<xsd:import namespace="http://ws/" schemaLocation="QueryService_schema1.xsd"/>
</xsd:schema>
</types>
<message name="Q1">
<part element="tns:Q1" name="parameters"/>
</message>
<message name="Q1Response">
<part element="tns:Q1Response" name="parameters"/>
</message>
<portType name="QueryDelegate">
<operation name="Q1">
<input message="tns:Q1"/>
<output message="tns:Q1Response"/>
</operation>
</portType>
<binding name="QueryPortBinding" type="tns:QueryDelegate">
<soap:binding style="document" transport="http://schemas.xmlsoap.org/soap/http"/>
<soap:operation soapAction=""/>
<input>
<soap:body use="literal"/>
</input>
<output>
</output>
</operation>
</binding>
<service name="QueryService">
<port binding="tns:QueryPortBinding" name="QueryPort">
<soap:address location="http://localhost:9088/Test_JAX_WS_Web/QueryService"/>
</port>
</service>
</definitions>
</pre>
Original Schema<br />
<?xml version="1.0" encoding="UTF-8"?><xs:schema targetNamespace="http://ws/" version="1.0" xmlns:tns="http://ws/" xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:element name="Q1" type="tns:Q1"/>
<xs:element name="Q1Response" type="tns:Q1Response"/>
<xs:complexType name="Q1">
<xs:sequence>
<xs:element minOccurs="0" name="arg0" type="xs:string"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="Q1Response">
<xs:sequence>
<xs:element minOccurs="0" name="return" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
</pre>
BIRT seems to have difficulty handling the type reference and cannot determine the input parameters or the return type. I edited the schema file and BIRT was able to get all information.<br />
Edited schema<br />
<xs:element name="Q1">
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="Q1Response">
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
</pre>
This works. BIRT is able to list the parameters correctly. <br />
Is this a bug? Is there a workaround?<br />
Thanks <br />
Paul
There are no comments yet
