Passing Drill Down Parameters to another report not being read by Datset
BlackaJ
I am new to Birt and am experiencing an issue with drill thorugh charting.
I have a Dataset that reads data from an Oracle 11 DB.
The report is a line chart that has Start and End Date Parameters and this produces a chart as expected
- I am using the beforeOpen event on the Dataset to filter using the parameters.
I require to click on the Chart and the Start and End Date Parameters be passed to the second report and
Filter on these passed parameter values.
The issue that I am encountering is that the passed parameter values do not appear to be read by the beforeOpen event on the Dataset of the Second Report.
If I run the second report in its own and enter parameters, it works as expected.
To ensure that the values are being passed through, I have placed the parameter objects to the report and the passed data is appearing - hence is being populated.
Any help would be appreciated
mwilliams
If you can create a master and detail report with the sample database and attach them in here, so I can see exactly what you're doing and test on the reports, that'd be great! Thanks!
BlackaJ
<blockquote class='ipsBlockquote' data-author="'mwilliams'" data-cid="107945" data-time="1344021851" data-date="03 August 2012 - 12:24 PM"><p>
If you can create a master and detail report with the sample database and attach them in here, so I can see exactly what you're doing and test on the reports, that'd be great! Thanks!<br /></p></blockquote>
Hi, I have solved the issue.<br />
I had a combo box with a pre populated list in the second report parameter.<br />
When I changed to a Text box it worked as expected.<br />
Thanks
mwilliams
Glad you got it working! Let us know whenever you have questions!
