BIRT Viewer Encoding problem
julisonne
Hello,
I have the following problem:
I designed a report within Eclipse Juno. The report contains parameters (default value) and labels with umlauts (??????). When I viewed the report with eclipse it worked.
But our reports should run with JBoss and viewed with the BIRT-Viewer. I copied the report to the renamed WebViewerExample and typed the URL in the browser to view it with the BIRT-Viewer. Then I got a message like:
Report Design Object is not available
When I delete the ??? the report worked and was displayed with BIRT-Viewer.
The report is UTF-8 and the BIRT-Viewer Version is 4.2.0. JBoss Version is 7.1.1-final.
I tried to change the encoding of the report to ISO-8859 but eclipse/BIRT automatically changes the encoding to UTF-8.
I hope you could help me.
mwilliams
Can you attach an example report, that I can run, that will show me the issue? Thanks!
julisonne
Hello,
I designed an example report and attached it. It has parameters (default value) for the address and labels with ???. I also have problems with ? and the permill sign so I include it to the example report too.
I hope it helps to understand my problem...
mwilliams
I didn't have any issues with the report when I deployed it to the webviewerexample on JBoss. I have JBoss 5.0.1, though, not 7.1.1.
