Problem with auto colors for grouped and stacked bar charts
dermoritz
i am creating grouped and stacked bar charts via birt-chart-api. The result looks as follows:<br />
kclark
dermoritz,<br />
You could do something like this in the onRender() of your chart<br />
function beforeDrawDataPoint( dph, fill, icsc )
var sValue = dph.getSeriesValue();
dph.get
if(sValue == "b1,m") {
fill.set(r, g,
} else if (sValue == "b1,w")
fill.set(r, g,
} // And so on for the stacked bars
function beforeDrawLegendItem(lerh, bounds, icsc)
label = lerh.getLabel();
labelString = label.getCaption().getValue();
if(labelString == "b1,m") {
lerh.getFill().set(r,g,B);
} else if (labelString == "b1,w")
} // And so on for the rest of your legend
</pre>
If you have only a few groups you could try the above code. This will let you choose what colors for each series in your chart and change the legend to match.
dermoritz
thx,<br />
but in meantime i solved the problem.<br />
The problem was the bad javadoc. It is working if the used integers are negative! So if you want to shift color one position so that a "BarSeries" begins with the second color (red instead of blue) you have to call<br />
<pre class='_prettyXprint _lang-auto _linenums:0'>groupSeries.getSeriesPalette().shift(-1);</pre>
So in my case i call<br />
<pre class='_prettyXprint _lang-auto _linenums:0'>groupSeries.getSeriesPalette().shift(-lastBarSeriesSize);</pre>
(This was not the first time that i stumbled badly over the missing or bad documentation - i also got the 2 birt books but they didn't help neither :-P )
kclark
Thanks for the update on that, glad you got it working!
