Help with simple IF Then statement
iwcnb
I am having a problem writing a simple IF THEN statement that compares a date in the text field to Today's date. I tried using a variable to assign Today's date after the equal operation, but it seems like I am not allow to do that. Here is my script:
<iw_perl><![CDATA[
sub DateTime{
($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) = localtime(time);
my $date = sprintf("%2.2d/%2.2d/%4.4d ",$mon+1,$mday,$year+1900);
]]></iw_perl>
<iw_if expn='{iw_value name="Headline.Date"/} eq "$date" '>
<iw_then>
<![CDATA[<img src="/images/NewToday.gif" width="1" height="1" border="0" alt="">]]>
</iw_then>
</iw_if>
Is what I am doing correct or I missed something here.
Greatly appreciate if someone can show me a work around.
Thanks!
Migrateduser
I think there may be a couple of problems here? $date is only being populated inside the subroutine - so it should be local to that sub and not visible outside? And the sub is never being called? Plus don't you want dcr.Headline.Date (I am not sure).
<iw_perl><![CDATA[
sub DateTime
return( sprintf("%2.2d/%2.2d/%4.4d ",$mon+1,$mday,$year+1900));
my ${date} = DateTime();
<iw_if expn='{iw_value name="dcr.Headline.Date" /} eq {iw_value name="${date}" /}'>
iwcnb
John,
I use your version of the script but I still did not get it to work. I did not get any error. If I hardcode the value Today's date (02/28/2003) in place of the ${date} then it work. But placing the variable ${date} as the value did not work at all.
Also, the reason I did not have "dcr.Headline.Date" is that the IF statement is with an <iw_iterate> tag.
Any ideas?
Migrateduser
Can you post or email the DCT and TPL?
Adam Stoller
<font color='brown'>If I hardcode the value Today's date (02/28/2003) in place of the ${date} then it work. But placing the variable ${date} as the value did not work at all.</font>
I think the quoting is wrong in the example that was posted - the outer-most quotes should be double-quotes (") not single-quotes (') - otherwise the variables within will not be interpolated. So I think what's happening is that you're comapring the date from the DCR with the literal string "${date}" instead of its value.
--fish
iwcnb
John - Here is my DCR and TPL.
<?xml version="1.0" standalone="no"?>
<!DOCTYPE datacapture SYSTEM "datacapture5.0.dtd">
<data-capture-requirements type="content" name="Headlines">
<!-- data-capture-requirements elements contain area elements -->
<ruleset name="Info Headlines">
<description>
InfoLink Home Page Headlines
</description>
<item name="Headline">
<label>Headlines</label>
<replicant default="1" min="1" max="10">
<item name="Date">
<description>Date format is MM/DD/YYYY.</description>
<text required="t" maxlength="10" validation-regex="^[0-1][0-9]/[0-3][0-9]/[0-9][0-9][0-9][0-9]$" />
</item>
<item name="HeadlineText">
<textarea cols="82" rows="15" wrap="virtual" external-editor="visualformat" external-editor-inline="t" />
</item>
</replicant>
</item>
</ruleset>
</data-capture-requirements>
TPL:
<?xml version="1.0" encoding="UTF-8"?>
<iw_pt name="Headlines">
<![CDATA[
dim strdate
strDate = date()
function FixDate(strDate)
dim NewDate,TodaysDate
NewDate = strDate
if instr(left(NewDate,2),"/") then
NewDate = "0" & NewDate
end if
if mid(NewDate,5,1) = "/" then
NewDate = left(NewDate,3) & "0" & mid(NewDate,4)
end if
FixDate = NewDate
end function
'TodaysDate = FixDate(strDate)
'response.write TodaysDate
<html>
<head>
<title>Announcements</title>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=UTF-8">
</head>
<body bgcolor="#FFFFFF" leftmargin="0" topmargin="0" marginwidth="0" marginheight="0">
<table width="100%" border="0" cellspacing="1" cellpadding="1" vspace="4">]]>
<iw_perl><![CDATA[
sub DateTime
]]></iw_perl>
<iw_iterate list='dcr.Headline' var='Headline'>
<![CDATA[<tr>
<td valign="top">]]>
<iw_if expn='{iw_value name="Headline.Date"/} eq {iw_value name="${date}" /} '>
<iw_then>
<![CDATA[<img src="/images/new.gif" width="61" height="12" border="0" alt="">]]>
</iw_then>
</iw_if>
<![CDATA[<iw_value name="Headline.HeadlineText"/></td>
</tr>
<tr>
<td height="5"><img src="/images/dot.gif" width="1" height="1" border="0" alt=""></td>
</tr>
</iw_iterate>
<![CDATA[ </table>
</body>
</html>]]>
<!-- End CDATA tag -->
</iw_pt>
iwcnb
ghoti - base on the code that I have could you fix the code and provide the correct syntax?
Migrateduser
I think I found the answer to your problem.
Just after my ${date} = DateTime();, add another line chop($date);
What was happening is that there was a whitespace in $date in the end and so the comparison was failing.
Thanks
Migrateduser
Btw, does anybody know what happened to iwpt_output? There is no reference to this particular IW tag in the Templating Developers Guide. I have used it in older versions but haven't tested to see if it works in 5.5.2
Streamshare.zip
iwcnb
Saran,
I don't quite understand what you mean by line chop($date);? Could you provide an example?
thanks!
Migrateduser
chop - Chops off the last character of a string
$xyz = "abcd";
chop($xyz);
print "$xyz";
will print "abc" because the last character gets chopped.
I'm actually talking about some way to 'trim' as in other languages. I'm not a perl expert and this is one way I know how to do it, I hope it's right, if not some Perl gurus help us!
So, instead of
<iw_perl><![CDATA[
sub DateTime
]]></iw_perl>
if you have
<iw_perl><![CDATA[
sub DateTime
chop($date);
]]></iw_perl>
then for example "03/03/2003 " gets chopped to "03/03/2003" and the comparison will succeed.
Hope this helps now.
Migrateduser
Hmmm.. you know what, I was wondering why we have a whitespace in the first place. It's because you have this
Instead, if you had
my $date = sprintf("%2.2d/%2.2d/%4.4d",$mon+1,$mday,$year+1900);
there would not have been any problem. So, forget about chop!
Thanks
Adam Stoller
iwpt_output is not a tag - it is a method available within iw_perl to send output to the right place (you should use this instead of 'print')
--fish
