Problem with cascading parameters
xARNOx
Hello dear community,
well it's a bit difficult to explain my issue.
I Have two parameters (Parameter_A and Parameter_B ) and two Data Sets (Data_Set_1 and Data_Set_2).
I want Parameter_A as a Listbox which contains Values needed for Data_Set_1. But i want different display-texts for the Values on the parametermask.
The selected value from Parameter_A will be used (as i said) in Data_Set_1. The Values i get then from Data_Set_1 are the Values for Parameter_B. After this the user will select one of these Values in Parameter_B and this Value will be used in Data_Set_2.
I hope you understand me.
sry for bad english.
bricombs
Good Day
Take a look at the following sample on our DevShare:
Creating a set of Cascading Parameters in a BIRT report
http://www.birt-exchange.org/org/devshare/designing-birt-reports/73-birt-cascading-parameters/
xARNOx
thx for your answer.
I know how to create a cascading parameter group.
But I need a Listbox-parameter in this group with predefined values which have a different display text and dont know how to do this.
For Example:
the user gets a list of these 3 options from which he have to select one.
"Football"
"Tennis"
"Curling"
but the Values this options are standing for have not exactly the same name:
"Football" stands for "Foo%"
"Tennis" stands for "Ten%"
"Curling" stands for "Cur%"
look at the picture i attached.
I did not found out how to create such a parameter in the cascading parametergroup.
bricombs
Good Day
A Cascaded parameters group uses data from Data Sets. It does not allow you to use a static List Box like what you show in your screen shot. You could create a Parameter Group which allows you to use a static list box like you show. But a parameter group was not really designed to do cascaded paramters. So if you need cascaded paramters I would suggest that you create a data set for the data. For example you could put the values in a flat file and then create a data set from it. This would allow you to easly change the values with out editing the report.
xARNOx
Thanks for your advice.
I did it that way (create a data set for data) and it works fine.
Now I got 2 new questions.
First:
I have a new parameter (Parameter_C) in the Cascading Parameter Group which I need for a chart.
He contains only one value (defined by the other 2 parameters). So i dont want him to be on the parametermask, when starting the report, you now what I mean?
Second:
If I choose in the Parametermask a Value from the list of Parameter_A the field of Parameter_B becomes clear.
Is it possible that the default-value of Parameter_B is automatically the first line in the Data Set where it gets his data from?
Like a dynamic default-value you know?
bricombs
Good Day
For question 1:
If Parameter_C is used for a dataset you could try not using a paramter in the query and just filtering the data based on the values from Parameters A&B. Then you don't need to add C to the parameter mask.
For question 2:
There is no good way to dynamically set the default value of a parameter at runtime. You could try creating a custom parameter page to see if that would work.
http://birtworld.blogspot.com/2007/09/22-birt-tag-library-building-custom.html
messiii
It seems very complicated
