Need help with passing parameters to BIRT
kilo316
Hello,
I have created several BIRT reports that prompt the user for parameters and then pass them to the sql (using ? placed within the sql). I did this all using the BIRT IDE.
BUT, now I need to pass in a parameter in that contains sql, such as myID='1234' and have that placed into the BIRT report sql, and then have the BIRT report run using the sql passed in.
How do you do this? I think I have to use java script, but how can I implement this? Can someone provide an example????
Tubal
You can modify (or write) your dataset query in the beforeOpen event of the dataset using this.queryText.<br />
So for example:<br />
<pre class='_prettyXprint _lang-auto _linenums:0'>this.queryText = "SELECT * FROM myTable WHERE myColumn = " + params["myParam"];</pre>
Or you could just edit a portion of your dataset query:<br />
<pre class='_prettyXprint _lang-auto _linenums:0'>this.queryText = this.queryText.replace("/**some placeholder in my query**/","AND myID=" + params["myParam"]);</pre>
