problem placing Grid and Table side by side
yaragallamurali
<p>Hi i need to place Grid and Table in a single row. I mean both side by side. I have changed the display property of both the elements to "inline". Even after changing they are not being placed side by side. Is it possible to display them in a single row?</p>
yaragallamurali
<p>Any ideas on how to do this? This helps me a lot in my reports. Thanks in advance.</p>
micajblock
<p>Use a grid with 2 cells (one row 2 columns). Put the grid in one cell and the table in the other.</p>
yaragallamurali
<blockquote class="ipsBlockquote" data-author="mblock" data-cid="121007" data-time="1380991581"><div><p>Use a grid with 2 cells (one row 2 columns). Put the grid in one cell and the table in the other.</p></div></blockquote><p>ya really cool. Thank you so much. But really there is no use of display option which can be set as "inline" . So what is the point of having that property useless. Any ways the solution you provided is cool. That solves my problem anyway. Thank you so much.</p>
yaragallamurali
<blockquote class="ipsBlockquote" data-author="mblock" data-cid="121007" data-time="1380991581"><div><p>Use a grid with 2 cells (one row 2 columns). Put the grid in one cell and the table in the other.</p></div></blockquote><p>This did the magic and now my report looks awesome. Thank you so much. </p>
