iterate data set and display required values in grid
aniinprni
<p>Hi,</p><p> </p><p> i am having a dataset values ("parametername","parametervalue").</p><p> </p><p>now i need to loop dataset and place the correct value in the grid like if(parametername == "xxxx")then display corresponding parametervalue.</p><p> </p><p>how to loop data set and fetching the required values to corresponding columns</p><p> </p><p>i have found one solution that in each grid i have taken "LIST COMPONENT" and in the details of that i am writing visibility condition that</p><p> </p><p>if(dataSetRow["parametername"]=="xxxx"){</p><p> false</p><p>}</p><p> else true</p><p> </p><p>it is working fine in the preview but when i view it as pdf, it is showing whitespaces for which columns are hidden.</p><p> </p><p>i am still working on this since two days onwards.please help me out.</p>
kclark
<p>Do you have to use a grid? If you use a table then you can filter out all data you don't want by selecting the table > property editor > filters > add. Then from here you can use your parameter to filter out data you don't want in your table.</p>
aniinprni
<p>Hi,</p><p> </p><p> Thanks for your reply and support, but i have achieved this in query results in a single row.</p><p>But i will try this solution also.</p><p> </p><p>But i am facing another issue in the grid,</p><p> </p><p>if value is null i need to hide the "Label".</p><p> </p><p>for example i have 10 labels in my grid and the dataset is having only one record every time.</p><p> and each label i am writing "Visibility" condition like below</p><p> </p><p>if(row["CLINICALDIAGNOSIS"] != null ) {</p><p> false</p><p>}</p><p>else{</p><p>true</p><p>}</p><p> </p><p>for some labels it is working and for some labels it is not working.</p><p> </p><p>is there error in my code,Please help me out</p><p> </p><p>Thanks in adavnce.</p>
