Two parameters for same thing
jkpatton
<p>I have a report I'm trying to design that has two parameters that will give the same value, they're just sorted differently. The client wants to be able to look up a permit by its permit number, or look up a permit by the permit owner's name.</p><p> </p><p>I have a lookup query that selects the permit number, and the name.</p><p> </p><p>So I have one parameter that is sorted by permit number, and the value is the permit number. And I have one parameter that is sorted by name, and the value is the permit number. At this time I have both of the report parameters as "required" and in the lookup query there is a union which adds the '%' option to the list box.</p><p> </p><p>In the main report query I have a where clause that says</p><p> </p><p>Where permit_number = ?</p><p>and permit_number = ?</p><p> </p><p>and I have two parameters in the data set that are linked to the report parameters mentioned above.</p><p> </p><p>If I use these parameters individually and take out the "AND permit_number=?" I get results. If I try to use them together, I do not get results.</p><p> </p><p> Ideas? If anything is unclear I'll try to make it clearer.</p><p> </p><p> </p>
kclark
<p>Why use both parameters as required? Can't you just have one parameter and then have some SQL like the following</p><pre class="_prettyXprint">select *from tablewhere permit like %param1% or like %param2%</pre>
