Problems with drill-through in separate paths
coderman77
<p>I have a reporting folder structure that looks something like this:</p><p> </p><p>reports</p><p> drillthroughs</p><p> mydrillthrough1.rptdesign</p><p> mydrillthrough2.rptdesign</p><p> Main.rptdesign</p><p> </p><p>Whats happening is Main.rptdesign has a hyperlink that drills through to mydrillthrough1.rptdesign. its path is set to "drillthroughs/mydrillthrough1.rptdesign"</p><p> </p><p>mydrillthrough1.rptdesign has a hyperlink on it that drills into mydrillthrough2.rptdesign. its drillthrough path is "mydrillthrough2.rptdesign"</p><p> </p><p>The first drillthrough works fine, but when clicking on the 2nd drill through i get an error that it cant find the path to the second file because it seems to be relative to the main report and not relative to the drill through that launched it.</p><p> </p><p>Has anyone run into this?</p><p> </p><p> </p>
GLO_FR
<div>What version of BIRT and Viewer are you using ?</div><div>Did this happen on the designer or on the server ?</div><div> </div><div>I've tested it with BIRT 4.3.1 and it works fine.</div>
