Using iServer and iHub F-Type on the Same Machine
VSafonov
<p>While reading through the pre-requisites fot iHub install I have noticed it requires same ports as the iServer. Is it possible to install iHub on a same machine as the iServer?</p>
Clement Wong
<p>It is possible to have both an iServer, and iHub or F-Type on the same machine. However, it is <strong>not recommended</strong> because ports will be needed to be changed on the iHub or F-Type so that it does not conflict with the existing iServer.</p>
<p> </p>
<p>If you want F-Type running on the same machine, one option is to download the F-Type VM Linux image (<a data-ipb='nomediaparse' href='
http://www.actuate.com/info/ihubftype-vmware'>http://www.actuate.com/info/ihubftype-vmware</a>)
and run the VM on the same machine. The host machine will require VMWare Player 6.0.3. And the VM uses:</p>
<ul><li> CentOS 6.5</li>
<li> 2 Virtual CPUs</li>
<li> RAM: 4 GB</li>
<li> Free Disk Space: 6 GB<br>
</li>
</ul>
VSafonov
<p>At the Customer Days it was explained to me that iHub can coexist with the iServer on a same machine by the way of some config changes. Since my machine IS a VMWare image partitioning it is not an option. Can't I just "fix" all the ports manually? If yes - is there a list of configs I need to change?</p>
JFreeman
<p>Could you please provide some additional details about the use case for having both iHub F-Type and iServer on the same machine?</p>
<p> </p>
<p>Are you wanting to have both iServer and iHub F-Type running simultaneously or do you plan on only having one or the other running at any given time? </p>
VSafonov
<p>iServer is our "legacy" application with 100s of reports and Actuate queries. I am looking to have BIRT functionality available for our users. Since it can not be integrated into iServer I need iHub running in parallel to iServer. iServer is CPU bound so we have resources available on the box.</p>
JFreeman
<p>Although I do not know the details of your environment, BIRT functionality is available and can be utilized and implemented within an iServer.</p>
<p> </p>
<p>Could you please elaborate on how BIRT functionality cannot be integrated into your iServer?</p>
<p>What is the business/technical requirement which is preventing BIRT functionality from being available within your iServer?</p>
VSafonov
<p>1. Your latest features like analytics and 360 are only available under iHub. So when we were discussing a possibility of purchasing licenses it was explained that it would be only available in iHub and it wouldn't be a problem running them in parallel.</p>
<p> </p>
<p>forgot 2... - this one is free.</p>
micajblock
<p>Technical issues aside, the issue here is licensing. Check here for more information - <a data-ipb='nomediaparse' href='
http://developer.actuate.com/be/documentation/ihubftype3/help/faq/index.html#page/Freemium-FAQ/FAQ-Prerequisites.1.10.html'>http://developer.actuate.com/be/documentation/ihubftype3/help/faq/index.html#page/Freemium-FAQ/FAQ-Prerequisites.1.10.html</a></p>
<p> </p>
<p>Specifically - For a single application, you may not combine installations or copies of BIRT F-Type or any other software licensed on a commercial basis from Actuate or a third party licensor.</p>
