BIRT Analytics ODA connection problem
raghavyadavm
<p>Hi,</p>
<p> I have downloaded the oda from this url <a data-ipb='nomediaparse' href='
http://developer.actuate.com/community/forum/index.php?/files/file/1093-oda-for-birt-analytics/'>http://developer.actuate.com/community/forum/index.php?/files/file/1093-oda-for-birt-analytics/</a> and
copied the .jar files into plugin directory of eclipse and restarted i could find the profile only for fastDBA but couldnt find for analyis.</p>
<p> </p>
<p>Thanks,</p>
<p>Raghav</p>
<p> </p>
micajblock
<p>Did you unzip the dependencies in to the plug-ins directory also?</p>
raghavyadavm
<p>Yup! even i have copied the unzipped versions of dependencies into the plugin directory.</p>
bolmstead
<p>Are you using BIRT Designer Pro, or Open Source? Latest version? I would suggest downloading and installing the latest version of the designer. Then, when you copy the dependencies into the plugins folder, choose "do not replace" during file conflicts. Is this Windows or Mac?</p>
<p> </p>
<p>Thanks</p>
<p>Brett</p>
