<p>We integrated the Birt Report Engine 4.4.1 (OSGI) in our web application.</p>
<p>After swiching to Java 8, we get the following exception.</p>
<p>There is a bug report in</p>
<p><a data-ipb='nomediaparse' href='
https://bugs.eclipse.org/bugs/show_bug.cgi?id=449165'>https://bugs.eclipse.org/bugs/show_bug.cgi?id=449165</a></p>
<p>which is solved in 4.4.2.</p>
<p> </p>
<p>When will a new OSGI runtime be released?</p>
<p>Or is there another solution?</p>
<p> </p>
<p> </p>
<p><span style="font-size:12px;"><span style="font-family:'times new roman', times, serif;"> CAUSED BY:<br>
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.<br>
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2363)<br><br>
CAUSED BY:<br>
java.lang.NullPointerException: null<br>
at org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.getMappedFont(FontHandler.java:213)<br>
at org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.selectFont(FontHandler.java:172)<br>
at org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter.buildChunk(FontSplitter.java:98)<br>
at org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter.getNext(FontSplitter.java:189)<br>
at org.eclipse.birt.report.engine.layout.pdf.text.ChunkGenerator.getNext(ChunkGenerator.java:104)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.TextCompositor.getNextTextArea(TextCompositor.java:189)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.TextCompositor.getNextArea(TextCompositor.java:127)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.TextAreaLayout.layoutChildren(TextAreaLayout.java:182)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.TextAreaLayout.layout(TextAreaLayout.java:173)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.BlockTextArea.layout(BlockTextArea.java:74)<br>
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.startContent(LayoutEngine.java:564)<br>
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startText(ContentEmitterAdapter.java:147)<br>
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startLabel(ContentEmitterAdapter.java:153)<br>
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:65)<br>
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.visitContent(LayoutEngine.java:715)<br>
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.visitContent(LayoutEngine.java:723)<br>
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.visitChildren(LayoutEngine.java:739)<br>
at org.eclipse.birt.report.engine.nLayout.RegionLayoutEngine.layout(RegionLayoutEngine.java:31)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.PageArea.layoutHeader(PageArea.java:457)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.PageArea.initialize(PageArea.java:248)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.RootArea.createNewPage(RootArea.java:147)<br>
at org.eclipse.birt.report.engine.nLayout.area.impl.RootArea.initialize(RootArea.java:138)<br>
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.setContainer(LayoutEngine.java:368)<br>
at org.eclipse.birt.report.engine.nLayout.LayoutEngine._startContainer(LayoutEngine.java:456)<br>
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.startContainer(LayoutEngine.java:355)<br>
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startPage(ContentEmitterAdapter.java:65)<br>
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.startPage(CompositeContentEmitter.java:290)<br>
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:47)<br>
at org.eclipse.birt.report.engine.layout.html.buffer.PageNode.start(PageNode.java:49)<br>
at org.eclipse.birt.report.engine.layout.html.buffer.ContainerBufferNode.start(ContainerBufferNode.java:79)<br>
at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.startContent(HTMLPageBuffer.java:113)<br>
at org.eclipse.birt.report.engine.layout.html.buffer.TableBreakBuffer.startContent(TableBreakBuffer.java:287)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.start(HTMLLeafItemLM.java:67)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:139)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)<br>
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)<br>
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)<br>
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)</span></span></p>
<p>Thanks,</p>
<p>Renate</p>
