Manual changes to be Made for .xml files for Externalization Birt using RSSE
raghavyadavm
<p>Hi,</p>
<p> What are the changes that to be made in the xml files for Externalization and Authorization of the Birt Ihub using the RSSE API ,where the credentials are read from a text file/JSON file.</p>
<p> </p>
<p>Thanks,</p>
<p>Raghav</p>
JFreeman
<p>I'm not sure I understanding exactly what you ask.</p>
<p>Can you please provide more details on what you are wanting to know about using RSSE with a flat file?</p>
<p> </p>
<p>A good place to start with implementing an RSSE is the documentation here: <a data-ipb='nomediaparse' href='
http://developer.actuate.com/be/documentation/ihub3-dev/aig-main/index.html#page/aig/UsingJavaRSSE.html'>http://developer.actuate.com/be/documentation/ihub3-dev/aig-main/index.html#page/aig/UsingJavaRSSE.html</a></p>
<p> </p>
<p>An example of an RSSE implementation can be found on GitHub here: <a data-ipb='nomediaparse' href='
https://github.com/ActuateBIRT/ServerIntegrationRSSEExample'>https://github.com/ActuateBIRT/ServerIntegrationRSSEExample</a></p>
raghavyadavm
<p>I am trying to implement the Example file of RSSE implementation present in this link <a data-ipb='nomediaparse' href='
https://github.com/ActuateBIRT/ServerIntegrationRSSEExample'>https://github.com/ActuateBIRT/ServerIntegrationRSSEExample</a>and
i'm using the trail version of IHub F-Type 3.1, so i am unable to use System Console for Configuring IHUB for the necessary RSSE SOAP Parameters. So what are the changes to be made to the <span style="color:rgb(51,51,51);font-family:'Helvetica Neue', Helvetica, 'Segoe UI', Arial, freesans, sans-serif;font-size:16px;">acserverconfig.xml</span></p>
JFreeman
<p>Implementing a custom RSSE with an F-Type installation is not supported. You will need to look towards upgrading to a full iHub license in order to implement a custom RSSE.</p>
<p> </p>
<p>An F-Type installation can be configured to use an Active Directory or LDAP to externalize users/groups however, this is done with a specific utility that configures the F-Type to use the bundled LDAP Adapter.</p>
<p> </p>
<p>The LDAP Adapter utility can be found in the DevShare here: <a data-ipb='nomediaparse' href='
http://developer.actuate.com/community/forum/index.php?/files/file/1104-utility-to-enable-ldap-with-birt-ihub-f-type/'>http://developer.actuate.com/community/forum/index.php?/files/file/1104-utility-to-enable-ldap-with-birt-ihub-f-type/</a></p>
<p> </p>
<p>I have also written a blog post on using the utility here: <a data-ipb='nomediaparse' href='
http://blogs.actuate.com/how-to-configure-birt-ihub-f-type-to-use-active-directory-or-ldap/'>http://blogs.actuate.com/how-to-configure-birt-ihub-f-type-to-use-active-directory-or-ldap/</a></p>
