QLoader project won't end, Need help to stop it!
wsloan311
<p>I ran my QLoader project yesterday, its still running today, it won't finish and there is no way to stop it. I can't get back into my project to do any work until it finishes and I'm on a deadline to get some things done. Anyone know how i can stop the project???</p>
<p> </p>
<p> </p>
<p> </p>
JFreeman
<p>You can first try stopping the services for FastDB and the Tomcat holds BIRT Analytics.</p>
<p> </p>
<p>If that also has issues, you can manually kill the processes. The process name for FastDB is "dubnium.exe" and the tomcat process name could vary some depending on your configuration. In a default installation it will be "tomcat7.exe".</p>
