<p>Hello,</p>
<p> </p>
<div>We are facing problems while trying to connect to an external database(EnterpriseDB) through iHub server. </div>
<div> </div>
<div>We have BIRT iHUB 3.1 server (Product Version:BIRT iHub 3.1 (Build 231A150206)) and have done default installation. After that we are connecting to an external database using the cluster database switcher tool, following the System Administrator guide at -</div>
<div> </div>
<div><a data-ipb='nomediaparse' href='
http://developer.actuate.com/be/documentation/ihub31-dev/sag/index.html#page/admin/Installing_BIRT_iHub_AltRDBMS_Linux.05.4.html'>http://developer.actuate.com/be/documentation/ihub31-dev/sag/index.html#page/admin/Installing_BIRT_iHub_AltRDBMS_Linux.05.4.html</a></div>
<div> </div>
<div>On running the cluster database switcher tool, following sql exception occurs - </div>
<div> </div>
<div>[iaruser@rhel7-iar1 bin]$ sh switch_cluster_database.sh switch_cluster_database.properties</div>
<div>Detailed information will be logged to file "/usr/local/kits/iHub/BIRTiHubVisualization/modules/BIRTiHub/iHub/data/server/log/ClusterDatabaseSwitcher.rhel7-iar1.2015-06-26_06_00_49-0400.%g.log"</div>
<div>Enter the source database user password:</div>
<div>Enter the target database user password:</div>
<div>Enter the target database administrator password:</div>
<div>Initializing source...</div>
<div>Initializing target...</div>
<div>Switching from PostgreSQL database "ihub" to PostgreSQL database "ppasiar"...</div>
<div>Transferring cluster data...</div>
<div>Performing data store operations on PostgreSQL schema "ac_volume"...</div>
<div>Creating database user...</div>
<div>Creating user "ihub"...</div>
<div>SEVERE: Could not connect to database "jdbc:actuate:postgresql://test-host:5444;DatabaseName=ppasiar" as "xxxxxxx"</div>
<div><strong>[ActuateDD][PostgreSQL JDBC Driver]The Connect Series for JDBC PostgreSQL Wire Protocol driver is only licensed to connect to PostgreSQL databases. You are attempting to connect to the following type of server: EnterpriseDB</strong></div>
<div>SEVERE: Could not connect to database</div>
<div>SEVERE: Error performing data store operations</div>
<div>SEVERE: Data store operations failed - see log for details</div>
<div>SEVERE: Error initializing target</div>
<div>SEVERE: Error initializing data store copier</div>
<div>SEVERE: Error switching to PostgreSQL database "ppasiar"</div>
<div> </div>
<div> </div>
<div>Can you please help in resolving this exception? Do we need to do any changes to make it recognize EnterpriseDB?</div>
<div> </div>
<div>Please find log file and properties file attached for your reference.</div>
