Validation script for parameters does not work when the parameters are not included as part of the g
divyani
<p>Hi,</p>
<p> </p>
<p>In my report, there are two date parameters (From Date and To Date). I have written validation for these parameters. When the report is run alone, it works fine. But when i include the report in a dashboard and insert the parameters <u>not as part</u> of the report gadget, the validation is not being done.Is there any way in which the problem can be solved.</p>
<p> </p>
<p>P.S: When the report parameters(From Date and To Date) are included as part of the gadget in the dashboard then the validation works fine. </p>
<p> </p>
<p>Thanks in advance!</p>
<p> </p>
<p> </p>
JFreeman
<p>Which version of the iHub are you using?</p>
<p> </p>
<p>Can you provide some more information on the specifics of your code setup?</p>
<p> </p>
<p>Where is the validation code located?</p>
<p>How are you passing the parameters in when the validation does not run?</p>
<p>Are you using a selector gadget?</p>
