Problem getting group total on first page
QDeca
<p>Hello,</p>
<p> </p>
<p>I'm creating a report displaying a table organized into groups, and I would like to display the sum of values pertaining to a group, but in the first page. I already found a solution to get the page total for each page, but for a group total it seems to be a lot more complicated. The catch is that :</p>
<p> </p>
<p>- I can"t really get that from a modification from the SQL query, because I tried and added a column like that : (select (sum(value) from Table t2 where t1.group = t2.group)) ; but all it did was make Eclipse freeze, due to the fact that the table is far too massive to be read multiples times like this. (Perhaps there is a better way that doesnt involve re-reading the table?)</p>
<p> </p>
<p>- I would like to avoid putting it on the masterpage if possible, since I'd like the total to come right after the last row of the table.</p>
<p> </p>
<p>I've created a report using the Classic Models data source which recreates a part of my report, in which I've left blank the space where my group total should be.</p>
<p> </p>
<p>If anyone has the time to check it out and see if they have any idea how to solve this, I would be really grateful.</p>
<p> </p>
<p>Thanks in advance and thanks for reading anyway.</p>
<p> </p>
<p>Qdeca</p>
nimpo
<div>Hello,</div>
<div> </div>
<div>I had the same blocking and the only workaround found was to create a separate query that generates the sum and I displays it directly to the first page.</div>
<div> </div>
<div>and if someone another solution I am also interested :ph34r:</div>
RRK
<p>Hi,</p>
<p> </p>
<p>I have attached a modified report where I have added aggregated column in table which calculates group total.</p>
<p> </p>
<p>Is this you were looking for ?</p>
<p> </p>
<p>Please let me know</p>
<p> </p>
<p> </p>
QDeca
<p>That seems to work perfectly ! I expected that to be a lot harder to solve, thanks a lot for your solution !</p>
RRK
<p>Good to hear this ...
</p>
<p> </p>
<p>Cheers!!!</p>
