Please help: BIRT Output Side-by-side tables Use Excel Format
wzc314159
<p>Dear all, I want to create side-by-side tables using Excel output. I use 3*2 grid to divide the panel. It's seemed all right when using Report Viewer, but not OK when output using Excel, all content is in one cell. I try to use "Dynamic Text" but can't create data binding. Please give me some hints to solve this, many thanks and regards.</p>
<p>
Shweta Parihar
<p>Which version of BIRT designer are you using?</p>
wzc314159
<blockquote class="ipsBlockquote" data-author="Shweta Parihar" data-cid="144879" data-time="1470769102">
<div>
</div>
</blockquote>
<p>Hi, I'm using the newest version of BIRT.</p>
sureshpulapalli
<p>Is it eclipse birt or Actuate Birt? Is this issue for both the formats Excel and XLSX?</p>
jfranken
<p>The easiest way I can think of to implement this report is to create two data sets, one for customers and one for employees. Place a grid on the report that has one row and two columns. Dragging a data set from the Data Explorer tab to the layout automatically creates a table on the report containing the columns in the data set, so dragging the customers data set into the left cell of the grid will create a table for customers on the left side of the report. Dragging the employees data set into the right cell of the grid will create a table for employees on the right side of the report. </p>
<p> </p>
<p>Using this method to create side-by-side tables in BIRT 4.6, the formatting issue still occurs when the report is exported to XLSX. Both of the tables are inserted into a single spreadsheet cell. However, exporting to XLS or ODS (which can be opened in Excel) causes the tables to display properly.</p>
<p> </p>
<p>If the XLSX format is a requirement, it might be possible to get a fix for this issue:</p>
<p><a data-ipb='nomediaparse' href='
https://bitbucket.org/yaytay/spudsoft-birt-excel-emitters/issues?responsible=yaytay'>https://bitbucket.org/yaytay/spudsoft-birt-excel-emitters/issues?responsible=yaytay</a></p>
<p> </p>
<p>Edit: I forgot to mention that the XLSX emitter in the professional version of BIRT handles the export properly (tested in BRDPro 4.4.0).</p>
<p> </p>
<p>Regards,</p>
<p>Jeff</p>
