Using variable for passing values in birt report
Elja
<p>Hello.<br>
I'm creating a report, in which I need to calculate a value of 2 fields, compare it to a 3.rd one. Depending on the values, I need to calculate a value and pass it to the next row and repeat the calculations there.</p>
<p> </p>
<p>I desperately need some help. I already thought I had this solved, but as I ran the report again, the report doesn't produce any result set. Although the main data set preview shows the correct collection of dataset rows..</p>
<p> </p>
<p>I checked the table shouldn't contain any extra bindings and there are no visibility issues.</p>
<p>
Now, I created:</p>
<p>1) global variable "jaannos"</p>
<p>2) I copy the dataSetRow value "SUMMA" to the global variable in Main data sets onFetch -script as follows:</p>
<p>vars["jaannos"] = dataSetRow["SUMMA"].value;</p>
<p>* In the main table I computed the value like this:</p>
<p>if((row["LIIKAMAKSU"].value + row["KULUKORVAUS"].value) < vars["jaannos"].value)<br>
{<br>
(row["LIIKAMAKSU"].value + row["KULUKORVAUS"].value)<br>
}<br>
else {<br>
vars["jaannos"]<br>
}</p>
<p>3) I count the remaining value, if any like this to another dedicated field:</p>
<p>if((row["LIIKAMAKSU"].value + row["KULUKORVAUS"].value) < row["Muuttujan_arvo"].value)<br>
{<br>
row["Muuttujan_arvo"].value - (row["LIIKAMAKSU"].value + row["KULUKORVAUS"].value)<br>
}<br>
else {<br>
0<br>
//vars["jaannos"]<br>
}</p>
<p>4) I replace the global variable value with the remaining value like follows:</p>
<p>vars["jaannos"].value = row["Seur_rivi"].value;</p>
<p> </p>
<p>The points 2-4 are used as data fields expression formulas..</p>
<p> </p>
<p>RESULT:</p>
<p>No values appear in the report.</p>
<p> </p>
<p>Do you have any idea where the problem might be?</p>
<p> </p>
<p>- Elja</p>
micajblock
<p>Can you provide an example using a text file with dummy data? Also what version are you using?</p>
Elja
<p>Hey Mica.</p>
<p>Thanks for assistance. I created a simple excel file and tried to fix the report to get the data out of it.</p>
<p> </p>
<p>In the sample report I present 3 tables, one just showing the data from Excel.</p>
<p> </p>
<p>The second one resembles the report I'm trying to produce. no variable is here.</p>
<p> </p>
<p>The third one is similar to the second table, but doesn't work. In this one I try to use the variable..</p>
<p> </p>
<p>- Elja</p>
<p> </p>
<p>Ps. The way I'm trying to use the variable is explained in the "Using_variable.docx" -attachment.</p>
<p> </p>
micajblock
<p>What version of BIRT are you using?</p>
Elja
<p>sorry, forgot to mention: 4.6</p>
micajblock
<p>I was not able to run the report. Can you make sure the report runs without Oracle?</p>
Elja
<p>Hello Mblock.</p>
<p>My bad, I didn't remove the old data sources and sets and there was some binding left in the background.</p>
<p> </p>
<p>Now I removed them and it seems to do the job.</p>
<p>The tables are better looking in pdf-format.</p>
<p> </p>
<p>- Elja</p>
micajblock
<p>Are you still having an issue? I am still having problems running the report.</p>
<p> </p>
<p>P.S. Why do you use the notation of row["fieldname"]<strong>.value? </strong>There is no need for the '.value' (it is actually causing me issues when running reports?</p>
<p> </p>
<p>P.P.S. If you are still having issues can you share a screenshot of the 'Output Columns' tab of the data set so I can see what data types you are using. for some reason it is erasing it for me. Also provide details of what you are trying to accomplish.</p>
Elja
<p> </p>
<p>Yes, this problem still exists. I've been working on some other stuff and hoping I could find the answer from here.</p>
<p> </p>
<p>1) I've been using row["fieldname"].value -notation since we discovered that this was the necessary way to compare NULL-value in before open -script. I guess it shouldn't be done here. I'll test without the .value.</p>
<p> </p>
<p>2) I'll attach the output columns.</p>
<p> </p>
<p>3) The goal. I'll try to put this in a nut shell:</p>
<p>In this report, a value counted from a substraction (based on database field values) needs to be passed to the next row for a new calculation..</p>
<p> </p>
<p>Example:</p>
<p>* There are 3 values on row 1: A (Liikamaksu), B (Kulukorvaus), C (Summa)</p>
<p>Case 1: A+B < C, C-(A+
is transferred to the next row.</p>
<p>Case 2: A+B >= C, C is presented in the row, now value is transferred to the next row.</p>
micajblock
<p>Take a look at the simplified example</p>
Elja
<p>Hey Mica and thanks.</p>
<p> </p>
<p>I think there are some things in your example that need tuning:</p>
<p>1) The value of SUMMA should be presented, if SUMMA < LIIKAMAKSU + KULUKORVAUS</p>
<p>else "LIIKAMAKSU + KULUKORVAUS"</p>
<p>2) The remaining value of SUMMA - (LIIKAMAKSU + KULUKORVAUS) should be transmitted to variable and be used in the next rows calculation.</p>
<p>Let's see with an example:</p>
<p>LIIKAMAKSU = 300 (on each row)</p>
<p>KULUKORVAUS = 200 (on each row)</p>
<p>SUMMA = 1100 (original value, this will change row by row)</p>
<p> </p>
<p>* First row: SUMMA > LIIKAMAKSU + KULUKORVAUS; 1100 > 300+200 the value on this row should be "LIIKAMAKSU + KULUKORVAUS" = 500.</p>
<p>* For the next row, this LIIKAMAKSU+KULUKORVAUS -> 500 should be subtracted from old SUMMA to create the value of new SUMMA:</p>
<p>SUMMA (new) = SUMMA (former) - (LIIKAMAKSU + KULUKORVAUS) -> 1100 - 500 = 600.</p>
<p>* Second row: SUMMA (600) > (LIIKAMAKSU + KULUKORVAUS), 600 > 500. </p>
<p>Value of LIIKAMAKSU + KULUKORVAUS = 500 is presented. New SUMMA value is: 600-500 = 100. This is transmitted to the third row.</p>
<p>* Third row: SUMMA < (LIIKAMAKSU + KULUKORVAUS): 100 < 500. NOW, the value of SUMMA is presented (100).</p>
<p>As SUMMA was finally < LIIKAMAKSU + KULUKORVAUS, there's nothing to remain for the forth row and from now on the value of "LIIKAMAKSU + KULUKORVAUS" should be presented on each of the remaining rows.</p>
<p> </p>
<p>- Elja</p>
micajblock
<p>I am sorry, I am not sure I am clear on the logic. Instead of me can you provide a spreadsheet with formula's so I can be sure that I get it right? <br>
Thanks.</p>
Elja
<p>I created a simplified example in an excel sheet, in which I marked just the 3 fields in question and the value which reduces each time and is presented in the next row...</p>
<p> </p>
<p>Let's hope I'm able to explain this matter well enough this time.</p>
<p> </p>
<p>- Elja</p>
<p> </p>
<p>PS. I think I figured out one thing that might have made this case difficult to follow..</p>
<p>1) The field "Liikamaksu" and "Kulukorvaus" can differ on each row.</p>
<p>The field "Summa" is a one time value, which is sliced into many rows, never exceeding the sum of "Liikamaksu + kulukorvaus".</p>
<p> </p>
<p>In a nutshell: In "Summa" -field should be represented the value of either:</p>
<p>1) Summa, IF Summa <= Liikamaksu + Kulukorvaus.</p>
<p>2) Liikamaksu + Kulukorvaus, IF Liikamaksu + Kulukorvaus < Summa. AND in this case, the remaining value of "Summa - (Liikamaksu + Kulukorvaus)" is counted and used in the next rows Summa field! This will be repeated until Summa <= Liikamaksu + Kulukorvaus.</p>
Elja
<p>Hey, we managed to get this working. I'll explain shortly how..</p>
Elja
<p>Ok.</p>
<p>So, the basic dilemma was to obtain a certain value from database and then use it in Excel-like fashion on the report: to subtract the value of C from A+B until C < A+B and after that C = 0.</p>
<p> </p>
<p>Our solution for this matter was to use a variable and a computed field:</p>
<p> </p>
<p>1) we created a variable "jaannos" -> default value 0.</p>
<p>2) we created a computed field in the main data set: "Saatu_perittya" with the following formula:</p>
<p><strong><span style="color:#7f0055;"><span style="font-family:consolas;"><span style="font-size:10pt;">if</span></span></span></strong><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;"> (row[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"LIIKAMAKSU"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">] + row[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"KULUKORVAUS"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">] < row[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"SUMMA"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">] - vars[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"jaannos"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">]) {</span></span></span></p>
<p><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;"> row[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"LIIKAMAKSU"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">] + row[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"KULUKORVAUS"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">]</span></span></span></p>
<p><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">}</span></span></span></p>
<p><strong><span style="color:#7f0055;"><span style="font-family:consolas;"><span style="font-size:10pt;">else</span></span></span></strong> <strong><span style="color:#7f0055;"><span style="font-family:consolas;"><span style="font-size:10pt;">if</span></span></span></strong><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">(row[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"SUMMA"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">] - vars[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"jaannos"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">] > 0) {</span></span></span></p>
<p><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;"> row[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"SUMMA"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">] - vars[</span></span></span><span style="color:#2a00ff;"><span style="font-family:consolas;"><span style="font-size:10pt;">"jaannos"</span></span></span><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">]</span></span></span></p>
<p><strong><span style="color:#7f0055;"><span style="font-family:consolas;"><span style="font-size:10pt;">else</span></span></span></strong><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;"> {</span></span></span></p>
<p><span style="color:#000000;"><span style="font-family:consolas;"><span style="font-size:10pt;">0</span></span></span></p>
<p> </p>
<p>* Here, LIIKAMAKSU = A, KULUKORVAUS = B and SUMMA = C. C is the value that is obtained once from the database and after that diviced into many rows after it's been used.</p>
<p> </p>
<p>3) variable "jaannos" is given a new value also in computed column "Col_Jaannos":</p>
<p>vars["jaannos"] += row["LIIKAMAKSU"] + row["KULUKORVAUS"]</p>
<p>-> jaannos (new) = jaannos (old) + A + B</p>
<p> </p>
<p>Now, this will affect the formula shown in number 2 to give the correct values to the report.</p>
<p>I didn't go with the onFetch script anymore as it seemed to be run on every row. (Before I thought it was run once).</p>
<p> </p>
<p>- Elja</p>
micajblock
<p>So you have a solution? I was going to look at this, this morning.</p>
micajblock
<p>I think I created a much simpler solution. I have one report variable named 'nextRow' with an initial value of -1. Then I have a a single data binding with this expression. It seems to work. Let me know if this works for you.</p>
<div>
<pre class="_prettyXprint">
if (vars["nextRow"]==-1) {
vars["nextRow"]=row["SUMMA"];
if (row["LIIKAMAKSU"]+row["KULUKORVAUS"]<vars["nextRow"]) {
vars["nextRow"]=vars["nextRow"]-(row["LIIKAMAKSU"]+row["KULUKORVAUS"]);
row["LIIKAMAKSU"]+row["KULUKORVAUS"];
else {vars["nextRow"]}</pre>
</div>
<p> </p>
