Data Deploy - Urgent Help required
HemaKK
Im using an Oracle Database. While trying to create the mapping for DCT to Schema for one particular field it throws an ERRORas :
Error: 500
Internal Servlet Error:
java.lang.NullPointerException
at com.interwoven.dd100.ui.TSaveGroupUtils.saveColumn(TSaveGroupUtils.java:345)
at com.interwoven.dd100.ui.ProcessGroupServlet.doPost(ProcessGroupServlet.java:175)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
at com.interwoven.framework.base.FrameworkServlet.service(FrameworkServlet.java:66)
at com.interwoven.framework.auth.AuthServlet.service(AuthServlet.java:96)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.apache.tomcat.core.ServletWrapper.doService(ServletWrapper.java:405)
at org.apache.tomcat.core.Handler.service(Handler.java:287)
at org.apache.tomcat.core.ServletWrapper.service(ServletWrapper.java:372)
at org.apache.tomcat.core.ContextManager.internalService(ContextManager.java:797)
at org.apache.tomcat.core.ContextManager.service(ContextManager.java:743)
at org.apache.tomcat.service.http.HttpConnectionHandler.processConnection(HttpConnectionHandler.java:213)
at org.apache.tomcat.service.TcpWorkerThread.runIt(PoolTcpEndpoint.java:423)
at org.apache.tomcat.util.ThreadPool$ControlRunnable.run(ThreadPool.java:501)
at java.lang.Thread.run(Thread.java:484)
This Field is has a referential Integrity constraint defined and is a Foreign Key.
Please help me out as soon as possible.
Thanks & Regards
Hema K
Michael
Perhaps you could post as an attachment the DCT and the command you are running, platform, DD version etc etc.....
Bubas_IWOV
Can you please post the full log, please.
HemaKK
Thanks Micheal & Bubas. I have got rid of the error message. Actually the problem was in the way of saving the mapping. Since im using a referntial integrity constraint for foreign Key, i was supposed to first map the Parent tables & then the child tables.
But still im not able to deploy Data. There exists one Table "Channel" which has a primary Key "channel id". Another table has this "channel id" defined as a foreign key(Referential Integrity constraint is defined). Now i need to map Channel table also since its refernced as a foreign key. But i dont want data to be deployed to the Channel Table. Its trying to deploy & throws exception. Im attaching the LOG file.
Please help me out figure what mistake im making.
Thanks in advance
Hema K
Michael
Can you attach your DCT and DD config file?
Cheers, Michael.
HemaKK
Hi Micheal,
im attaching the dbschema.cfg, config file & datacapture.cfg.
Thanks
Hema K
Michael
Hi Hema,
If you don't want to deploy to a table then don't include it in your dbschema. It looks like you are only including channel, genre and subgenre because they are referenced by the tables you actually wish to insert show etc. You don't need to do this.
Put show in as your root group. Forget about referencing its FK parent for this deployment.
You should hopefully be sorted then.
Cheers
Michael
