I'm having trouble installing / configuring Avanced Document Transformation Services (6.5 on Documentum 6.5).
The installation seems to go fine, but when I then try to use the config util to set up an instance on this service, I initially got a DM_QUERY2_E_TABLE_NOT_FOUND error message saying "invalid object name 'joran.sandberg.cts_instance_info'.
I first checked that there are no trouble with the locale settings on the servers, and that seems to be ok.
I suspected that the period in my user name was the problem, so I created a new superuser with no period in the user name, and tried again (even with uninstall of ADTS, not just reconfig). But now the error message is telling me that the util cannot create a table since the name is not fully qualified (it tries to create 'cts_instance_info', not 'suprusr.cts_instance_info'.
Has anybody had similar errors?
Jøran Sandberg
