<![CDATA[<!--[if gte mso 9]>
Normal
false
false
false
MicrosoftInternetExplorer4
]]><![endif]><![if gte mso 9]><![CDATA[<xml>
<![endif]-->
<!--[if gte mso 10]>
/* Style Definitions */
table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
<![endif]-->]]>
Hi Everyone,
I am new on this foroum.I may post this discussion in the wrong place,please redirect me to the correct one.
I am
working on EMC DMX3 devices. I am getting a null value when I try to enumerate
the instances using CIM_ComputerSystem and CIM_DiskDrive using the association
CIM_SystemDevice.This is according to what is mentioned in the SMIS
specification.
Also,there
are instances for CIM_ComputerSystem and CIM_DiskDrive.So the problem
that I figure out is because of the CIM_SystemDevice association class.
Is this
true?
Is this a
problem with EMC DMX3 devices ?
Can you
please help me regarding this issue?
Sorry for
the trouble.
Thank you
Tejas Saner
