I am using DFS 6.5 with java to retrieve a document from documentum. The dfs-client.xml has entries for the various services being used over HTTPS. I have specified the path of the keystore file and its password in my code for communication over https. The DFS consumer code(as a jar) along with all the required jars and the dfs-clinet.xml are placed in TIBCO from where the consumer code is called as a service. When the code is invoked, i get the following exception
<?xml version = "1.0" encoding = "UTF-8"?>
<ns0:ErrorReport xmlns:ns0 = "http://www.tibco.com/pe/EngineTypes">
<StackTrace>The method [com.RetrieveDocument.retrieveDocument] raised exception [com.exception.MyException]. com.exception.MyException: ServiceException occured while executing the query- 'select r_object_id from dm_document where object_name = 'abc.pdf' and any r_version_label IN ('1.0')' com.emc.documentum.fs.rt.ServiceInvocationException: Service "com.emc.documentum.fs.services.core.QueryService" is not available at url: "https://<server>:9082/services/core/QueryService?WSDL" at com.emc.documentum.fs.rt.context.impl.DfsSoapService.newWebServiceClient(DfsSoapService.java:156) at com.emc.documentum.fs.rt.context.impl.DfsSoapService.getInstance(DfsSoapService.java:46) at com.emc.documentum.fs.rt.context.impl.DfsCachedService.getInstance(DfsCachedService.java:30) at com.emc.documentum.fs.rt.context.impl.DfsCachedUnlessChangedService.getInstance(DfsCachedUnlessChangedService.java:26) at com.emc.documentum.fs.rt.context.impl.compat.ClientReflectionServiceInvokerCompat60.invoke(ClientReflectionServiceInvokerCompat60.java:31) at com.emc.documentum.fs.rt.context.impl.SoapClientInvocationHandler.invoke(SoapClientInvocationHandler.java:64) at com.emc.documentum.fs.rt.context.impl.UcfClientInvocationHandler.invoke(UcfClientInvocationHandler.java:47) at com.emc.documentum.fs.rt.context.impl.MtomCompatHandler60SP1.invoke(MtomCompatHandler60SP1.java:55) at com.emc.documentum.fs.rt.context.impl.HttpSessionInvocationHandler.invoke(HttpSessionInvocationHandler.java:65) at com.emc.documentum.fs.rt.context.impl.OperationOptionsHandler.invoke(OperationOptionsHandler.java:48) at com.emc.documentum.fs.rt.context.impl.ReturnedContentTransformationHandler.invoke(ReturnedContentTransformationHandler.java:44) at com.emc.documentum.fs.rt.context.impl.ContextThreadLocalInvocationHandler.invoke(ContextThreadLocalInvocationHandler.java:46) at com.emc.documentum.fs.rt.context.impl.ServiceContextInvocationHandler.invoke(ServiceContextInvocationHandler.java:30) at $Proxy17.execute(Unknown Source) at com.RetrieveDocument.retrieveDocument(RetrieveDocument.java:296) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at com.tibco.plugin.java.JavaMethodActivity.for(JavaMethodActivity.java:351) at com.tibco.plugin.java.JavaMethodActivity.eval(JavaMethodActivity.java:121) at com.tibco.pe.plugin.Activity.eval(Activity.java:209) at com.tibco.pe.core.TaskImpl.eval(TaskImpl.java:540) at com.tibco.pe.core.Job.a(Job.java:712) at com.tibco.pe.core.Job.k(Job.java:502) at com.tibco.pe.core.JobDispatcher$JobCourier.a(JobDispatcher.java:249) at com.tibco.pe.core.JobDispatcher$JobCourier.run(JobDispatcher.java:200) Caused by: javax.xml.ws.WebServiceException: Failed to access the WSDL at: https://<server>:9082/services/core/QueryService?WSDL. It failed with: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. at com.sun.xml.ws.wsdl.parser.RuntimeWSDLParser.tryWithMex(RuntimeWSDLParser.java:162) at com.sun.xml.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:144) at com.sun.xml.ws.client.WSServiceDelegate.parseWSDL(WSServiceDelegate.java:263) at com.sun.xml.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:226) at com.sun.xml.ws.client.WSServiceDelegate.<init>(WSServiceDelegate.java:174) at com.sun.xml.ws.spi.ProviderImpl.createServiceDelegate(ProviderImpl.java:104) at javax.xml.ws.Service.<init>(Service.java:56) at com.emc.documentum.fs.services.core.QueryService.<init>(QueryService.java:48) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27) at java.lang.reflect.Constructor.newInstance(Constructor.java:494) at com.emc.documentum.fs.rt.context.impl.DfsSoapService.newWebServiceClient(DfsSoapService.java:143) ... 26 more Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at com.sun.net.ssl.internal.ssl.Alerts.getSSLException(Alerts.java:150) at com.sun.net.ssl.internal.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1518) at com.sun.net.ssl.internal.ssl.Handshaker.fatalSE(Handshaker.java:174) at com.sun.net.ssl.internal.ssl.Handshaker.fatalSE(Handshaker.java:168) at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:848) at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:106) at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Handshaker.java:495) at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Handshaker.java:433) at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:818) at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1030) at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1057) at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1041) at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:402) at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:170) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:938) at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:234) at java.net.URL.openStream(URL.java:1007) at com.sun.xml.ws.wsdl.parser.RuntimeWSDLParser.createReader(RuntimeWSDLParser.java:805) at com.sun.xml.ws.wsdl.parser.RuntimeWSDLParser.resolveWSDL(RuntimeWSDLParser.java:262) at com.sun.xml.ws.wsdl.parser.RuntimeWSDLParser.parse(RuntimeWSDLParser.java:129) ... 37 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:221) at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:145) at sun.security.validator.Validator.validate(Validator.java:203) at com.sun.net.ssl.internal.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:172) at com.sun.net.ssl.internal.ssl.JsseX509TrustManager.checkServerTrusted(SSLContextImpl.java:320) at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:841) ... 52 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:236) at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:194) at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:216) ... 57 more at com.tibco.plugin.java.JavaMethodActivity.for(JavaMethodActivity.java:372) at com.tibco.plugin.java.JavaMethodActivity.eval(JavaMethodActivity.java:121) at com.tibco.pe.plugin.Activity.eval(Activity.java:209) at com.tibco.pe.core.TaskImpl.eval(TaskImpl.java:540) at com.tibco.pe.core.Job.a(Job.java:712) at com.tibco.pe.core.Job.k(Job.java:502) at com.tibco.pe.core.JobDispatcher$JobCourier.a(JobDispatcher.java:249) at com.tibco.pe.core.JobDispatcher$JobCourier.run(JobDispatcher.java:200)</StackTrace>
<Msg>The method [com.RetrieveDocument.retrieveDocument] raised exception [com.exception.MyException]. com.exception.MyException: ServiceException occured while executing the query- 'select r_object_id from dm_document where object_name = abc.pdf' and any r_version_label IN ('1.0')' com.emc.documentum.fs.rt.ServiceInvocationException: Service "com.emc.documentum.fs.services.core.QueryService" is not available at url: "https://<server>:9082/services/core/QueryService?WSDL"
... 26 more
... 37 more
... 52 more
... 57 more
</Msg>
The problem is that the same code runs perfectly fine when executed as a stand-alone java program (outside TIBCO).
We replaced the certificate file in TIBCO, checked the password, did all possible things but it just doesnt work. Also, the same code works in TIBCO with http.
Please help.
Thanks in advance.
