Hi all,
I am trying to install CenterStage Pro.I am facing following Error in the installer_debug.log file.
******** Installtion Drive
******************:C:\
Free disk available on diskspace:17
Installation drive have enough diskspace:C:\
Start : MSMQCheckAction
**** MSMQ installed version
***5
**** IIS installed: ****true
**** Asp.NET installed: ****true
**** SERVICE_CHECK_RESULTS: ****CenterStage has detected a problem with one or more of the following pre-installation requirements:
Messaging Queuing: Installed IIS: Installed ASP.NET 2.0 or higher: Installed The installation process cannot be completed. Please make sure all pre-installation requirements are met before installing CenterStage.
searching classpath contents...
I am using following configuration:
Windows 2003 sp2
4GB RAM AND 40 GB HDD
MS SQL SERVER 2005 SP2 external DB.I even tried with inbuilt SQL 2005 Express DB.
I have configured all the below pre-installtion requirements.IIS,SMTP,MSMQ,.Net Framework 2.0 ,asp.net,MS Office.
I have not configured SSL.Do i need to enable it?
I have attached the log file found in C:// drive..
Regards,
karthick s
