Massive deployment speed difference OD 5.5.2
nipper
This is strange. I have a WF that I run an iwodstart, it takes 4 seconds to run. My customer wants a custom menu item to deploy. Fine. Using the same deployment, OD takes 1 minute 41 seconds. This is on the same machine, just copying to /tmp. I have included the logfiles. OD runs for almost 2 minutes, just very slowly from the custom menu item.
Name (ID) Start Target Status Elapsed Owner Actions
configfilesinstance (m177) 4/18/03 3:19 PM e02k34(mylocalhost.move config) completed 0:00:04 rc572c
configfilesinstance (m179) 4/18/03 3:43 PM e02k34(mylocalhost.move config) completed 0:01:41 rc572c
I have included the logs. Any clue ? I need a drink.
Adam Stoller
FWIW - your
slow
deployment is deploying from
/.iwmnt/default/...
(the non-caching mount-point), while your
fast
/default
which is, I believe, essentially deploying from the caching (
/iwmnt
no '
') mount point.
My guess is you are supplying the path for the source of the deployment as part of the custom script, before doing so - just use a little regex:
$path =~ s|^/\.?iwmnt||;
and see if that fixes the problem.
--fish
12386.pdf
nipper
huge freaking difference. I was being lazy (OK so that is a big surprise) and just grabbing $area_path from the environment variable. That did include /.iwmnt
Thanks a bunch Fish
Andy
Migrateduser
just want to point out KB 49776 .
for dirdiff and filelist deployments, there is some exposure, so
it might be better to use /.iwmnt (the non-cached mount).
for tsbased deployments, use /default.
the drawback of /.iwmnt is the perf slow-down.
there is known enhancement that is planned for OD5.6 SP2 (?)
