Problem with datacapture.cfg
cliffhanger
I was trying to create a datacapture form for a news release in /WORKAREA/work/templatedata/museum/news directory. My datacapture.cfg looks like the following:
<?xml version ="1.0" standalone = "no"?>
<!DOCTYPE data-capture-requirements SYSTEM "datacapture5.0.dtd">
<data-capture-requirements type = "content">
<ruleset name = "News Release">
</ruleset>
</data-capture-requirements>
When I ran iwxml_validate.ipl on this file, it kept giving me "datacapture.cfg not well-formed at line 1, column 0" error. Can anyone tell why it might do that when it looks syntactically alright? OR what is it that I am doing wrong here?
-Cliffhanger
lhdavis
Shouldn't it be "<!DOCTYPE datacapture SYSTEM "datacapture5.0.dtd">", using datacapture in the DOCTYPE instead of data-capture-requirements? That might have been a change with 6.0. Also, don't you need to specify the name "news" such as "<data-capture-requirements type = "content" name="news">? You might need at least one item in your ruleset as well (didn't have the 5.0 dtd handy to check. Just my $0.02.
Luke Davis
Open Technology Group, Inc.
luke.davis@med.va.gov
Dwayne
Make sure that the <?xml ... > line starts right at the left margin. If there's a space before the <, then it's not valid XML, at least according to the parser that Interwoven is using. Not sure if that's a part of the standard or not.
The rest of the lines don't matter, but it does for the control instruction line
Current project: TS 5.5.2/6.1 W2K
lhdavis
I looked at the 5.0 dtd and the name is IMPLIED and you can have zero or many items. So I would follow Dwayne's advice on checking for spaces or special characters.
Luke Davis
cliffhanger
Before I could try out the suggestions already posted, I am having another trouble here!! When I do DIR in the \WORKAREA\work\templatedata\safari\news\ directory I see the datacapture.cfg, or when I try opening the file from the command prompt, it opens it fine, but when I was running iwxml_validate.ipl on it, it says "No such file or directory". I checked the permission on the file and also its properties, they all look in lace.
Any idea why iwxml_validate.ipl can't see the file?
Thanks!!!
-Cliffhanger
Dwayne
My guess is that is in fact finding datacapture.cfg. The file that it's NOT finding, I would guess, is the DTD. Try running it with the
-well
paramter, which tells it not to validate against the DTD, and only check for well-formedness
cliffhanger
Thanks! Once again you're right!
-Cliffhanger
cliffhanger
hi,
what's the difference between using "<!DOCTYPE datacapture SYSTEM "datacapture5.0.dtd">" and "<!DOCTYPE data-capture-requirements SYSTEM "datacapture5.0.dtd">"? I was using data-capture-requirements at the first place because that's what it suggests in the tutorial
But oddly enough in the sample templates that came with the software, they're using "datacapture" instead.
Thanks
-Cliffhanger
