I am trying to set up DAS to work in my Teamsite environment: Teamsite 6.1 + DD 5.6a. And I have configured it to work partially. When I submit a changed DCRs, the DAS works fine and database get updated, but when I save a DCR, the DAS throw some errors.
Here is an example from iwddd.log file:
------------------Submit a DCR------------------------------------
TWorkItem:
oIt --- sock=2345 id=9
msg [cfg="Y:\default\main\Microsite_Can_Eng\WORKAREA\wa_staging/templatedata/ctcmicrosite/answers/answers_dd.cfg" deployment=submitlist myarea="/default/main/Microsite_Can_Eng/WORKAREA/wa_staging" mytable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING mybasetable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_STAGING mybasetablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS mybasetablenamesuffix=MAIN_MICROSITE_CAN_ENG_STAGING mytablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS mytablenamesuffix=MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING mysubmitlist=C:\ddtemp\sj8. ]
id=9 fDdArgs[0]=[cfg="Y:\default\main\Microsite_Can_Eng\WORKAREA\wa_staging/templatedata/ctcmicrosite/answers/answers_dd.cfg"]
id=9 fDdArgs[1]=[deployment=submitlist]
id=9 fDdArgs[2]=[myarea="/default/main/Microsite_Can_Eng/WORKAREA/wa_staging"]
id=9 fDdArgs[3]=[mytable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING]
id=9 fDdArgs[4]=[mybasetable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_STAGING]
id=9 fDdArgs[5]=[mybasetablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS]
id=9 fDdArgs[6]=[mybasetablenamesuffix=MAIN_MICROSITE_CAN_ENG_STAGING]
id=9 fDdArgs[7]=[mytablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS]
id=9 fDdArgs[8]=[mytablenamesuffix=MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING]
id=9 fDdArgs[9]=[mysubmitlist=C:\ddtemp\sj8.]
Database Vendor set to oracle
SQL datatype for column Path is varchar(255)
SQL datatype for column IW_State is varchar(255)
SQL datatype for column QSTN_PATH is varchar2(255)
SQL datatype for column DSPL_ORD_NO is Number(10)
SQL datatype for column ANS_VLU_TXT is varchar2(2000)
# of columns: 5
# of primary key columns specified: 1
# of groups defined in element: 1
Area VPath:/default/main/Microsite_Can_Eng/WORKAREA/wa_staging
Setting up TDbSchemaSynchronizer.
Validating cached connection...
Cached connection OK
Connected to [turing.radius:1521:maxdb]
SELECT * FROM USER_TABLES WHERE TABLE_NAME='TS_MC_ANS_TBL'
Table [TS_MC_ANS_TBL] exists.
SELECT * FROM USER_TABLES WHERE TABLE_NAME='IWTRACKER'
Table [iwtracker] exists.
TS_MC_ANS_TBL registered
Running deployment [submitlist]
extraction type=full
tuple mode=wide
area=/default/main/Microsite_Can_Eng/WORKAREA/wa_staging
filelist=[C:\ddtemp\sj8.]
/default/main/Microsite_Can_Eng/WORKAREA/wa_staging/templatedata/ctcmicrosite/answers/data/ca_en_microsite/SearsContest/elainetest
Generate DirectoryContents start:Mon Nov 29 11:16:58 EST 2004
Generate DirectoryContents end :Mon Nov 29 11:16:58 EST 2004
Generate TDCRTupleProducer start:Mon Nov 29 11:16:58 EST 2004
Generate TDCRTupleProducer end :Mon Nov 29 11:16:58 EST 2004
Path not found -- interpret as 'NotPresent'
Building replicant order column information.
Building replicant order column information... Done.
TUPLE={state=NotPresent, path=templatedata\ctcmicrosite\answers\data\ca_en_microsite\SearsContest\elainetest}
TTableSchemaHelper object for [TS_MC_ANS_TBL] found in cache.
SELECT
ELECT IW_State,QSTN_PATH,DSPL_ORD_NO,ANS_VLU_TXT,Path FROM TS_MC_ANS_TBL WHERE Path = ?
Recurse select: pIndex = 0, value = templatedata\ctcmicrosite\answers\data\ca_en_microsite\SearsContest\elainetest
BuildTuples:executeQuery returned valid result set
BuildTuples:BuildRows returned: true
DELETE: DELETE FROM TS_MC_ANS_TBL WHERE Path IN ( ?)
DoDelete: pIndex = 0, value = templatedata\ctcmicrosite\answers\data\ca_en_microsite\SearsContest\elainetest
-- Deleted
Filelist walk done
Filelist C:\ddtemp\sj8. deleted
UPDATE iwtracker SET UPDATETIME='Mon Nov 29 11:16:58 EST 2004' WHERE NAME='TS_MC_ANS_TBL'
1 row(s) updated.
Stat for group [answers]:
Rows inserted : 0
Rows updated : 0
Rows deleted : 1
Rows failed : 0
Rows rolled back : 0
Rows skipped : 0
Committing database [turing.radius:1521:maxdb]...
Deployment[submitlist]
DCRs inserted : 0
DCRs updated : 0
DCRs deleted : 1
DCRs failed : 0
DCRs rolled back : 0
DCRs skipped : 0
Started : Mon Nov 29 11:16:58 EST 2004
Finished: Mon Nov 29 11:16:58 EST 2004
### IWDataDeploy DONE ###
----------------------------Save a DCR---------------------------------
TWorkItem:
oIt --- sock=2345 id=12
msg [cfg="Y:/default/main/Microsite_Can_Eng/WORKAREA/wa_staging/templatedata/ctcmicrosite/answers/answers_dd.cfg" deployment=deltaupdate myarea="/default/main/Microsite_Can_Eng/WORKAREA/wa_staging" mybasearea="/default/main/Microsite_Can_Eng/STAGING" mytable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING mybasetable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_STAGING mybasetablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS mybasetablenamesuffix=MAIN_MICROSITE_CAN_ENG_STAGING mytablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS mytablenamesuffix=MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING myfilelist=C:\ddtemp\s2to. ]
id=12 fDdArgs[0]=[cfg="Y:/default/main/Microsite_Can_Eng/WORKAREA/wa_staging/templatedata/ctcmicrosite/answers/answers_dd.cfg"]
id=12 fDdArgs[1]=[deployment=deltaupdate]
id=12 fDdArgs[2]=[myarea="/default/main/Microsite_Can_Eng/WORKAREA/wa_staging"]
id=12 fDdArgs[3]=[mybasearea="/default/main/Microsite_Can_Eng/STAGING"]
id=12 fDdArgs[4]=[mytable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING]
id=12 fDdArgs[5]=[mybasetable=DEFAULT_CTCMICROSITE_ANSWERS__MAIN_MICROSITE_CAN_ENG_STAGING]
id=12 fDdArgs[6]=[mybasetablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS]
id=12 fDdArgs[7]=[mybasetablenamesuffix=MAIN_MICROSITE_CAN_ENG_STAGING]
id=12 fDdArgs[8]=[mytablenameprefix=DEFAULT_CTCMICROSITE_ANSWERS]
id=12 fDdArgs[9]=[mytablenamesuffix=MAIN_MICROSITE_CAN_ENG_WORKAREA_WA_STAGING]
id=12 fDdArgs[10]=[myfilelist=C:\ddtemp\s2to.]
# of columns: 5
ERROR:base-table attribute must be specified for .
ERROR:Exception4: java.lang.NullPointerException
at com.interwoven.dd100.dd.TDbSchemaUtils.IsPathColumnInGroup(TDbSchemaUtils.java:164)
at com.interwoven.dd100.dd.TDbSchemaGroupCfg.CheckReplicantOrderAsKeyCondition(TDbSchemaGroupCfg.java:377)
at com.interwoven.dd100.dd.TDbSchemaGroupCfg.(TDbSchemaGroupCfg.java:176)
at com.interwoven.dd100.dd.TDbSchemaCfg$TDbSchemaChildVisitor.VisitNode(TDbSchemaCfg.java:291)
at com.interwoven.dd100.dd.TConfiguration.TraverseChildElements(TConfiguration.java:925)
at com.interwoven.dd100.dd.TConfiguration.TraverseChildElements(TConfiguration.java:868)
at com.interwoven.dd100.dd.TDbSchemaCfg.(TDbSchemaCfg.java:67)
at com.interwoven.dd100.dd.TDatabaseCfg$TDatabaseChildVisitor.VisitNode(TDatabaseCfg.java:2366)
at com.interwoven.dd100.dd.TDatabaseCfg.ExtractAttributesAndVisitChildren(TDatabaseCfg.java:1901)
at com.interwoven.dd100.dd.TDatabaseCfg.(TDatabaseCfg.java:1568)
at com.interwoven.dd100.dd.TDeploymentCfg$TDestListChildVisitor.VisitNode(TDeploymentCfg.java:726)
at com.interwoven.dd100.dd.TDeploymentCfg$TDeploymentChildVisitor.VisitNode(TDeploymentCfg.java:473)
at com.interwoven.dd100.dd.TDeploymentCfg.(TDeploymentCfg.java:278)
at com.interwoven.dd100.dd.TConfiguration.GetDeployment(TConfiguration.java:209)
at com.interwoven.dd100.dd.IWDataDeploy.DetermineModes(IWDataDeploy.java:358)
at com.interwoven.dd100.dd.IWDataDeploy.Go(IWDataDeploy.java:474)
at com.interwoven.dd100.dd.TWorkItem.DoIt(TWorkItem.java:151)
at com.interwoven.dd100.dd.TLonelyWorker.run(TLonelyWorker.java:32)
at java.lang.Thread.run(Thread.java:479)
I noticed that when the deployment is "submitlist", it went through fine. But when the deployment is "deltaupdate", it fails.
And the following post is my ****_dd.cfg file for "submitlist" and "deltaupdate"
Do you know what else I need to do in order to make this deltaupdate deployment works?
Thanks a lot for help!!!
Edited by elin on 11/29/04 09:22 AM (server time).
