TSTemplating5.0.1 Installation Problem
cliffhanger
I installed TeamSite 5.0.1 and also TeamSite Templating, copied the appropriate files as instructed on the manual to the iw-home/local/config directory. Unfortunately, when I click "File>New Data Record" it pops up an error saying TS Templating is not installed properly; I am attaching a screenshot of the error and the error details.
Does this light anything in anyone's memory?
-Cliffhanger
Migrateduser
I wonder if that's related to
this yet unsolved mystery
Interwoven Humor Page
http://iw.simpleinternet.com
nipper
That window sure looks like you are using the java client rather than the HTML client. Is this
true ? Setting is in iw.cfg.
Could be JVM related as that is an old release & might work with an old JVM
HTH
Andy
cliffhanger
Should I rather use the HTML client then?
nipper
try it & see if it behaves any different, why fix a problem when you can hide it ?
cliffhanger
Thanks for your suggestion, but downloading some patch fixed the problem, so didn't really have to hide it
-cliffhanger
