Java based jobs not running
Hello!
I've recently modified the domain of the installation owner on the content server 6.7. All the necessary steps like changing the domain name in server.ini, registry keys and permissions on the file system were taken care.
We're facing one issue with the jobs where only dmbasic jobs are running while Java based jobs aren't running. Error message from the docbase log/ job properties is as follows:
FAILED: Could not launch method <<methodname>>: OS error: (No Error). DM error: ().
And from the JMS logs, I could find these error messages which are not pointing to any resolution:
ERROR [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/DmMail].[DoMail]] (http-0.0.0.0-9080-2) Servlet.service() for servlet DoMail threw exception
java.lang.Exception: Failed to create session. Error: [DFC_UNIFIED_LOGON_SETUP_FAIL] "Setup for unified logon failed. Please see the log for more details"
ERROR [org.jboss.security.auth.spi.UsersRolesLoginModule] (http-0.0.0.0-9080-2) Failed to load users/passwords/role files
java.io.IOException: No properties file: users.properties or defaults: defaultUsers.properties found
File system level permissions are set and are in place for the new domain.
NOTE: Only domain has changed, not the installation owner name.
Let me know if any pointers would help in resolving the issue.
  • edited August 15, 2016
    This may be the challenge. Check the Support Site for this article.
    Changing Content Server installation owner can cause Trusted Authentication to fail for ACS
  • edited August 16, 2016
    Hello Rouse
    I've already modified all the necessary configurations mentioned in that EMC resolution.
    But still the issue persists, none of these Java based jobs are running.
    In the Java Server start up bat file, I tried giving the account name both with and without domain, still it doesn't help.
    set JAVA_OPTIONS=-Duser.name=<installation owner>
    It might be useful to trace launch the method so that the entire request is visible in the docbase log. In that way you can see the call that the method is making to the method server. I believe that the method may somehow be unable to get a ticket for authentication from the Content Server.
  • I am facing same issue with documentum 16.4.
    Anyone please help!
  • Hello!
    Please check if the privileged clients were added and given appropriate rights.
  • checked..still same issue
  • Can you check the JMS config’s base URI name-value combination.
    Is it set correctly ?
  • checked...its correct
  • Alright! Now I need to know if the error message is exactly same and if not what lead you to this situation to imagine possible solution.
  • FAILED: Could not launch method : OS error: (No Error), DM error: ().
  • What lead you to this error, is it so that you also had to change domain ? Is it all jobs that are failing ?
  • only custom java jobs are getting failed,we upgraded recently from documentum 7.1 to 16.4 and since then jobs are not running.
  • Aren't your jobs modules ? If I remember right, all the jobs post 7.3 must be modules.
  • are you calling java_methods as modules?
  • Method depended jars/ libraries are traditionally saved on the JMS library location on CS
    but if the method is of type module then all the libraries are stored right into the CS .
    Methods of module style implement IDFModule
