D2.lockbox file or D2Method.passphrase property within it could not be found.
edited November 3, 2016 in Leap
Getting error when accessing cabinet in app . (log from rest services application)
15:45:51.672 [http-nio-8080-exec-9] DEBUG 40 - Start D2GetAdminTicketMethod method with JMS (Java Method Services)
15:45:51.786 [http-nio-8080-exec-9] ERROR 15 - D2.lockbox file or D2Method.passphrase property within it could not be found.
15:45:51.795 [http-nio-8080-exec-9] ERROR 40 - {}
java.io.IOException: Invalid decryption key.
        at com.emc.common.java.crypto.AESCrypto.decrypt(AESCrypto.java:113) [C6-Common-4.5.0.jar:na]
        at com.emc.common.java.crypto.AESCrypto.decrypt(AESCrypto.java:94) [C6-Common-4.5.0.jar:na]
        at com.emc.d2.api.methods.D2Method.start(D2Method.java:413) [D2-API-4.5.0.jar:na]
        at com.emc.d2.api.methods.D2Method.start(D2Method.java:239) [D2-API-4.5.0.jar:na]
Best Answer
  • edited October 19, 2016 Accepted Answer
    Per our communication I will proceed to close this request and the forum will be marked answered.  Below is a summary of the key points of this service request for your records:
    PROBLEM: D2.lockbox file or D2Method.passphrase property within it could not be found.
    CAUSE: Mismatching jar files,D2 REST and D2.
    RESOLUTION: Aligned all jars in D2 and D2 Rest to the same versions, reconfigured lockbox.
Answers
  • edited October 11, 2016
    Molarkr1,
    Thank you for moving this post to the LEAP space.  Our support will now be able to respond.
  • edited October 12, 2016
    It seems that this a lockbox issue, can you pleae confirm if you are using D2 rest 4.6 or 4.5 ?
    can you please confirm if you have D2/D2-Config  installed on the same machine, if so are you pointing to the same locbox ?
    Hi Ravi -
    Can you check if you have lockbox files under serverapps.ear\app-inf\classes. if not copy them.
    otherwise clear all cache, delete all old logs, restart all services and see if you still see the error.
    Regards,
    Rajesh
    I spoke with Ravi. The problem only happens with D24.5 REST API while using LEAP. D2 and D2-CONFIG works fine and no errors are reported. The error is seen in D2 REST logs. I have asked him to attach the logs for review.
    CS : 6.7 sp2
    D2 : 4.5 Patch 16
    D2 Rest : d2fs-rest-web-4.5.0
    Please use CMSClassUnloadingEnabled in place of CMSPermGenSweepingEnabled in the future
    10-Oct-2016 15:38:18.379 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version:        Apache Tomcat/8.0.32
    10-Oct-2016 15:38:18.380 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:          Feb 2 2016 19:34:53 UTC
    10-Oct-2016 15:38:18.380 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number:         8.0.32.0
    10-Oct-2016 15:38:18.380 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name:               Linux
    10-Oct-2016 15:38:18.381 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version:            2.6.32-573.18.1.el6.x86_64
    10-Oct-2016 15:38:18.381 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture:          amd64
    10-Oct-2016 15:38:18.381 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home:             /export/home1/jakarta/mdt/scripts/java64/1.7.0_17/jre
    10-Oct-2016 15:38:18.381 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:           1.7.0_17-b02
    10-Oct-2016 15:38:18.381 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:            Oracle Corporation
    10-Oct-2016 15:38:18.381 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:         /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService
    10-Oct-2016 15:38:18.381 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:         /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/conf/logging.properties
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:PermSize=96m
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:MaxPermSize=256m
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+CMSPermGenSweepingEnabled
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+CMSClassUnloadingEnabled
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.security.egd=file:///dev/./urandom
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms2048m
    10-Oct-2016 15:38:18.382 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
    10-Oct-2016 15:38:18.383 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/endorsed
    10-Oct-2016 15:38:18.383 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService
    10-Oct-2016 15:38:18.383 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService
    10-Oct-2016 15:38:18.383 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/temp
    10-Oct-2016 15:38:18.383 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/D2Lockbox/lib/native/linux_gcc34_x64::/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
    10-Oct-2016 15:38:19.115 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
    10-Oct-2016 15:38:19.131 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
    10-Oct-2016 15:38:19.133 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
    10-Oct-2016 15:38:19.138 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
    10-Oct-2016 15:38:19.138 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1194 ms
    10-Oct-2016 15:38:19.167 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
    10-Oct-2016 15:38:19.167 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.32
    10-Oct-2016 15:38:19.190 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web.war
    10-Oct-2016 15:38:24.971 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
    SLF4J: Class path contains multiple SLF4J bindings.
    SLF4J: Found binding in [jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/logback-classic-0.9.18.jar!/org/slf4j/impl/StaticLoggerBinder.class]
    SLF4J: Found binding in [jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/slf4j-log4j12-1.5.5.jar!/org/slf4j/impl/StaticLoggerBinder.class]
    SLF4J: Found binding in [jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
    SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
    15:38:29.570 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationFactory - Configuring ehcache from InputStream
    15:38:29.589 [localhost-startStop-1] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xmlns:xsi
    15:38:29.590 [localhost-startStop-1] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xsi:noNamespaceSchemaLocation
    15:38:29.614 [localhost-startStop-1] DEBUG net.sf.ehcache.util.PropertyUtil - propertiesString is null.
    15:38:29.617 [localhost-startStop-1] DEBUG net.sf.ehcache.CacheManager - No disk store path defined. Skipping disk store path conflict test.
    15:38:29.617 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheManagerEventListenerFactory class specified. Skipping...
    15:38:29.648 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:38:29.648 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:38:29.649 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:38:29.655 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:38:29.656 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:38:29.656 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:38:29.660 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:38:29.660 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:38:29.660 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:38:29.675 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - Initialised cache: attributeDataTypes
    15:38:29.675 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'attributeDataTypes'.
    15:38:29.675 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'attributeDataTypes'.
    15:38:29.675 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - Initialised cache: parentTypes
    15:38:29.675 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'parentTypes'.
    15:38:29.675 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'parentTypes'.
    15:38:29.688 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationFactory - Configuring ehcache from InputStream
    15:38:29.690 [localhost-startStop-1] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xmlns:xsi
    15:38:29.690 [localhost-startStop-1] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xsi:noNamespaceSchemaLocation
    15:38:29.691 [localhost-startStop-1] DEBUG net.sf.ehcache.util.PropertyUtil - propertiesString is null.
    15:38:29.691 [localhost-startStop-1] DEBUG net.sf.ehcache.CacheManager - No disk store path defined. Skipping disk store path conflict test.
    15:38:29.691 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheManagerEventListenerFactory class specified. Skipping...
    15:38:29.695 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:38:29.696 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:38:29.696 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:38:29.700 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:38:29.700 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:38:29.700 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:38:29.701 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - Initialised cache: d2-userPreferences
    15:38:29.701 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'd2-userPreferences'.
    15:38:29.701 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'd2-userPreferences'.
    15:38:29.708 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationFactory - Configuring ehcache from InputStream
    15:38:29.710 [localhost-startStop-1] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xmlns:xsi
    15:38:29.710 [localhost-startStop-1] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xsi:noNamespaceSchemaLocation
    15:38:29.712 [localhost-startStop-1] DEBUG net.sf.ehcache.util.PropertyUtil - propertiesString is null.
    15:38:29.712 [localhost-startStop-1] DEBUG net.sf.ehcache.CacheManager - No disk store path defined. Skipping disk store path conflict test.
    15:38:29.712 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheManagerEventListenerFactory class specified. Skipping...
    15:38:29.716 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:38:29.716 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:38:29.716 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:38:29.722 [localhost-startStop-1] DEBUG net.sf.ehcache.util.PropertyUtil - propertiesString is null.
    15:38:29.723 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:38:29.723 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:38:29.723 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:38:29.723 [localhost-startStop-1] DEBUG net.sf.ehcache.Cache - Initialised cache: sessionManagers
    15:38:29.723 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'sessionManagers'.
    15:38:29.723 [localhost-startStop-1] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'sessionManagers'.
    15:38:29.757 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - DFC version : 7.2.0140.0148
    15:38:29.768 [localhost-startStop-1] DEBUG 15 - lockbox file exists = true
    15:38:29.769 [localhost-startStop-1] DEBUG 15 - force lockbox file with /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/D2Lockbox/D2.lockbox
    15:38:29.778 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - LoadOnStartup - START =====================================
    15:38:29.778 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - LoadOnStartup - HTTP Headers
    Remote : null (null)
    Locale : null
    Request Protocol : null
    Request Method : null
    Context Path : /rest-api-project
    Request URI : null
    Request encoding : null
    Request Parameters :
    Request Headers :
    15:38:29.786 [localhost-startStop-1] DEBUG 15 - Init classLoaderExclude
    15:38:29.787 [localhost-startStop-1] DEBUG 15 - Cannot find classLoaderExclude into D2FS.properties
    15:38:29.787 [localhost-startStop-1] DEBUG 15 - Init classLoaderFilter
    15:38:29.787 [localhost-startStop-1] DEBUG 15 - Cannot find classLoaderFilter into D2FS.properties
    15:38:29.890 [localhost-startStop-1] INFO  15 - searchClassesByNameAndInterface 0
    15:38:29.891 [localhost-startStop-1] DEBUG c.e.d.d.servlets.init.LoadOnStartup - Search plugins for LoadOnStartupListener => []
    15:38:29.891 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - LoadOnStartup - Standard Servlet :
    15:38:29.894 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - Cache BOCS URL disabled.
    15:38:29.896 [localhost-startStop-1] DEBUG 15 - Init D2FileCleaningTracker with /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/temp/D2FileCleaningTracker_rest-api-project.ser
    2016-10-10 15:38:30,686 0    [localhost-startStop-1] WARN  com.documentum.fc.impl.util.PBEUtils  - DfException:: THREAD: localhost-startStop-1; MSG: [DFC_API_W_ATTEMPT_TO_USE_DEPRECATED_CRYPTO_API] WARNING: Program attempts to use deprecated non-FIPS compliant cryptography API.  This is not recommended.  Please consult the documentation for more detail.   ; ERRORCODE: ff; NEXT: null
      at com.documentum.fc.impl.util.PBEUtils.decrypt(PBEUtils.java:125)
      at com.documentum.fc.impl.util.RegistryPasswordUtils.decrypt(RegistryPasswordUtils.java:114)
      at com.documentum.fc.common.DfPreferences$EncryptedPasswordHandler.isEncrypted(DfPreferences.java:2050)
      at com.documentum.fc.common.DfPreferences$EncryptedPasswordHandler.set(DfPreferences.java:2042)
      at com.documentum.fc.client.DfTypedObject.doSetString(DfTypedObject.java:1441)
      at com.documentum.fc.client.DfTypedObject.setString(DfTypedObject.java:1418)
      at com.documentum.fc.common.impl.preferences.TypedPreferences.loadProperty(TypedPreferences.java:465)
      at com.documentum.fc.common.impl.preferences.TypedPreferences.loadProperties(TypedPreferences.java:343)
      at com.documentum.fc.common.DfPreferences.loadProperties(DfPreferences.java:377)
      at com.documentum.fc.common.impl.preferences.PreferencesManager.<init>(PreferencesManager.java:38)
      at com.documentum.fc.common.DfPreferences.initialize(DfPreferences.java:64)
      at com.documentum.fc.common.DfPreferences.getInstance(DfPreferences.java:43)
      at com.documentum.fc.client.DfSimpleDbor.getDefaultDbor(DfSimpleDbor.java:78)
      at com.documentum.fc.client.DfSimpleDbor.<init>(DfSimpleDbor.java:66)
      at com.documentum.fc.client.DfClient$ClientImpl.<init>(DfClient.java:350)
      at com.documentum.fc.client.DfClient.<clinit>(DfClient.java:766)
      at com.emc.d2fs.dctm.servlets.init.SessionIterator.<init>(SessionIterator.java:77)
      at com.emc.d2fs.dctm.servlets.init.LoadOnStartup.getSessions(LoadOnStartup.java:441)
      at com.emc.d2fs.dctm.servlets.init.LoadOnStartup.processRequest(LoadOnStartup.java:164)
      at com.emc.d2fs.dctm.servlets.D2HttpServlet.execute(D2HttpServlet.java:242)
      at com.emc.d2fs.dctm.servlets.D2HttpServlet.doGetAndPost(D2HttpServlet.java:505)
      at com.emc.d2fs.dctm.servlets.D2HttpServlet.doGet(D2HttpServlet.java:115)
      at com.emc.d2fs.dctm.servlets.init.LoadOnStartup.init(LoadOnStartup.java:116)
      at javax.servlet.GenericServlet.init(GenericServlet.java:158)
      at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1238)
      at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1151)
      at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1038)
      at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4997)
      at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5289)
      at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
      at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
      at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
      at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
      at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:939)
      at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1812)
      at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
      at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
      at java.util.concurrent.FutureTask.run(FutureTask.java:166)
      at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
      at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
      at java.lang.Thread.run(Thread.java:722)
    2016-10-10 15:38:30,689 3    [localhost-startStop-1] WARN  com.documentum.fc.impl.util.PBEUtils  - DfException:: THREAD: localhost-startStop-1; MSG: [DFC_API_W_ATTEMPT_TO_USE_DEPRECATED_CRYPTO_API] WARNING: Program attempts to use deprecated non-FIPS compliant cryptography API.  This is not recommended.  Please consult the documentation for more detail.   ; ERRORCODE: ff; NEXT: null
      at com.documentum.fc.common.DfPreferences$PasswordHandler.encryptIfNecessary(DfPreferences.java:2016)
      at com.documentum.fc.common.DfPreferences$PasswordHandler.set(DfPreferences.java:2009)
      at com.documentum.fc.common.DfPreferences$EncryptedPasswordHandler.set(DfPreferences.java:2043)
    2016-10-10 15:38:30,729 43   [localhost-startStop-1] WARN  com.documentum.fc.impl.util.PBEUtils  - DfException:: THREAD: localhost-startStop-1; MSG: [DFC_API_W_ATTEMPT_TO_USE_DEPRECATED_CRYPTO_API] WARNING: Program attempts to use deprecated non-FIPS compliant cryptography API.  This is not recommended.  Please consult the documentation for more detail.   ; ERRORCODE: ff; NEXT: null
      at com.documentum.fc.common.impl.preferences.PreferencesManager.<init>(PreferencesManager.java:39)
    2016-10-10 15:38:30,892 206  [localhost-startStop-1] WARN  com.documentum.fc.impl.util.PBEUtils  - DfException:: THREAD: localhost-startStop-1; MSG: [DFC_API_W_ATTEMPT_TO_USE_DEPRECATED_CRYPTO_API] WARNING: Program attempts to use deprecated non-FIPS compliant cryptography API.  This is not recommended.  Please consult the documentation for more detail.   ; ERRORCODE: ff; NEXT: null
      at com.documentum.fc.common.DfPreferences$PasswordHandler.get(DfPreferences.java:2003)
      at com.documentum.fc.client.DfTypedObject.doGetString(DfTypedObject.java:619)
      at com.documentum.fc.client.DfTypedObject.getString(DfTypedObject.java:597)
      at com.documentum.fc.common.impl.preferences.TypedPreferences.getString(TypedPreferences.java:154)
      at com.documentum.fc.client.DfTypedObject.getStringUnchecked(DfTypedObject.java:674)
      at com.documentum.fc.common.DfPreferences.getGlobalRegistryPassword(DfPreferences.java:1140)
      at com.documentum.fc.client.impl.bof.classmgmt.ModuleManager.getSboHostLoginInfo(ModuleManager.java:409)
      at com.documentum.fc.client.impl.bof.classmgmt.ModuleManager.connect(ModuleManager.java:381)
      at com.documentum.fc.client.impl.bof.classmgmt.ModuleManager.init(ModuleManager.java:340)
      at com.documentum.fc.client.impl.bof.classmgmt.ModuleManager.getInstance(ModuleManager.java:43)
      at com.documentum.fc.client.security.impl.DfcIdentityPublisher.<init>(DfcIdentityPublisher.java:44)
      at com.documentum.fc.client.security.internal.RegistrationMgr.register(RegistrationMgr.java:34)
      at com.documentum.fc.impl.RuntimeContext.<clinit>(RuntimeContext.java:195)
      at com.documentum.fc.client.DfClient.<clinit>(DfClient.java:772)
    15:38:36.782 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - Free memory=1.5836375 GB, Total memory=1.8111572 GB
    15:38:36.784 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - LoadOnStartup - Free memory=1.5836375 GB. Total memory=1.8111572 GB.
    15:38:36.784 [localhost-startStop-1] INFO  c.e.d.d.servlets.init.LoadOnStartup - LoadOnStartup - END (7.025s) =====================================
    10-Oct-2016 15:38:37.137 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web.war has finished in 17,947 ms
    10-Oct-2016 15:38:37.138 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/examples
    10-Oct-2016 15:38:37.315 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/examples has finished in 177 ms
    10-Oct-2016 15:38:37.316 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/ROOT
    10-Oct-2016 15:38:37.330 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/ROOT has finished in 14 ms
    10-Oct-2016 15:38:37.331 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/manager
    10-Oct-2016 15:38:37.354 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/manager has finished in 23 ms
    10-Oct-2016 15:38:37.354 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/docs
    10-Oct-2016 15:38:37.368 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/docs has finished in 14 ms
    10-Oct-2016 15:38:37.368 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/host-manager
    10-Oct-2016 15:38:37.384 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/host-manager has finished in 16 ms
    10-Oct-2016 15:38:37.390 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
    10-Oct-2016 15:38:37.397 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
    10-Oct-2016 15:38:37.398 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 18260 ms
    15:45:43.788 [http-nio-8080-exec-4] DEBUG 40 - get value for showD2TasksOnly
    15:45:43.833 [http-nio-8080-exec-10] DEBUG c.e.d.d.aspects.InjectSessionAspect - Call next service D2BrowserService.getBrowserContent(..)
    15:45:43.915 [http-nio-8080-exec-10] INFO  15 - searchClassesByNameAndInterface 0
    15:45:43.915 [http-nio-8080-exec-10] DEBUG c.e.d.d.aspects.InjectSessionAspect - Search plugins for D2BrowserServicePlugin => []
    15:45:43.928 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/D2FS4DCTM-WEB-4.5.0.jar!/strings/content/Contents/Contents_en.properties
    15:45:44.078 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/D2-API-4.5.0.jar!/C6-dbor.properties
    15:45:44.079 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/D2-Widget-API-4.5.0.jar!/C6-dbor.properties
    15:45:44.082 [http-nio-8080-exec-10] DEBUG 46 - Default Url for d2-cache.xml is jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/C6-Common-4.5.0.jar!/com/emc/common/java/cache/d2-cache.xml
    15:45:44.100 [http-nio-8080-exec-10] DEBUG 46 - C6 SAX PARSER : org.apache.xerces.jaxp.SAXParserFactoryImpl
    15:45:44.113 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationFactory - Configuring ehcache from InputStream
    15:45:44.210 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xmlns:xsi
    15:45:44.211 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.config.BeanHandler - Ignoring ehcache attribute xsi:noNamespaceSchemaLocation
    15:45:44.222 [http-nio-8080-exec-10] DEBUG n.s.e.config.DiskStoreConfiguration - Disk Store Path: /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/temp
    15:45:44.230 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.util.PropertyUtil - propertiesString is null.
    15:45:44.246 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheManagerEventListenerFactory class specified. Skipping...
    15:45:44.249 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.249 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.249 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.259 [http-nio-8080-exec-4] DEBUG 40 - get value for showD2TasksOnly
    15:45:44.260 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.260 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.260 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.262 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.262 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.262 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.265 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.265 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.265 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.267 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.267 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.267 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.269 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.269 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.269 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.271 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.272 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.272 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.274 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.274 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.274 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.276 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.276 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.276 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.278 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.279 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.279 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.281 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.281 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.281 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.283 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.283 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.283 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.285 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.285 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.285 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.288 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.288 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.288 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.290 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.290 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.290 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.292 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.292 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.292 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.294 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.294 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.295 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.297 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.297 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.297 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.299 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.299 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.299 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.301 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.301 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.301 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.303 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - No BootstrapCacheLoaderFactory class specified. Skipping...
    15:45:44.303 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - CacheWriter factory not configured. Skipping...
    15:45:44.303 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - No CacheExceptionHandlerFactory class specified. Skipping...
    15:45:44.341 [http-nio-8080-exec-10] DEBUG n.s.e.s.c.f.DiskPersistentStorageFactory - Matching data file missing (or empty) for index file. Deleting index file /export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/temp/xml-cache.index
    15:45:44.342 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: xml-cache
    15:45:44.343 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'xml-cache'.
    15:45:44.343 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'xml-cache'.
    15:45:44.343 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: pdfprocessor-cache
    15:45:44.343 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'pdfprocessor-cache'.
    15:45:44.343 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'pdfprocessor-cache'.
    15:45:44.343 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: object_ids-cache
    15:45:44.343 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'object_ids-cache'.
    15:45:44.343 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'object_ids-cache'.
    15:45:44.344 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: font-config-file-cache
    15:45:44.344 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'font-config-file-cache'.
    15:45:44.344 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'font-config-file-cache'.
    15:45:44.344 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: file-cache
    15:45:44.344 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'file-cache'.
    15:45:44.344 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'file-cache'.
    15:45:44.347 [http-nio-8080-exec-10] DEBUG n.s.e.s.c.f.DiskOverflowStorageFactory - Deleting data file folder-cache.data
    15:45:44.348 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: folder-cache
    15:45:44.348 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'folder-cache'.
    15:45:44.349 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'folder-cache'.
    15:45:44.349 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: dctmfile-cache
    15:45:44.349 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'dctmfile-cache'.
    15:45:44.349 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'dctmfile-cache'.
    15:45:44.349 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: skin-file-cache
    15:45:44.349 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'skin-file-cache'.
    15:45:44.349 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'skin-file-cache'.
    15:45:44.349 [http-nio-8080-exec-10] DEBUG n.s.e.s.c.f.DiskOverflowStorageFactory - Deleting data file c2file-cache.data
    15:45:44.350 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: c2file-cache
    15:45:44.350 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'c2file-cache'.
    15:45:44.350 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'c2file-cache'.
    15:45:44.350 [http-nio-8080-exec-10] DEBUG n.s.e.s.c.f.DiskOverflowStorageFactory - Deleting data file dictionary_dql-cache.data
    15:45:44.355 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: dictionary_dql-cache
    15:45:44.356 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'dictionary_dql-cache'.
    15:45:44.356 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'dictionary_dql-cache'.
    15:45:44.356 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: taxonomy_matrix-cache
    15:45:44.356 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'taxonomy_matrix-cache'.
    15:45:44.356 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'taxonomy_matrix-cache'.
    15:45:44.356 [http-nio-8080-exec-10] DEBUG n.s.e.s.c.f.DiskOverflowStorageFactory - Deleting data file o2attrconfig-cache.data
    15:45:44.357 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: o2attrconfig-cache
    15:45:44.357 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'o2attrconfig-cache'.
    15:45:44.357 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'o2attrconfig-cache'.
    15:45:44.357 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: user_group-cache
    15:45:44.357 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'user_group-cache'.
    15:45:44.358 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'user_group-cache'.
    15:45:44.358 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: taxonomy_value-cache
    15:45:44.358 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'taxonomy_value-cache'.
    15:45:44.358 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'taxonomy_value-cache'.
    15:45:44.358 [http-nio-8080-exec-10] DEBUG n.s.e.s.c.f.DiskOverflowStorageFactory - Deleting data file skin-cache.data
    15:45:44.359 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: skin-cache
    15:45:44.359 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'skin-cache'.
    15:45:44.359 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'skin-cache'.
    15:45:44.359 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: o2options-cache
    15:45:44.359 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'o2options-cache'.
    15:45:44.359 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'o2options-cache'.
    15:45:44.359 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: dictionary_dico-cache
    15:45:44.359 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'dictionary_dico-cache'.
    15:45:44.359 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'dictionary_dico-cache'.
    15:45:44.360 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: bocs-cache
    15:45:44.360 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'bocs-cache'.
    15:45:44.360 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'bocs-cache'.
    15:45:44.360 [http-nio-8080-exec-10] DEBUG n.s.e.s.c.f.DiskOverflowStorageFactory - Deleting data file taxonomy_level-cache.data
    15:45:44.360 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: taxonomy_level-cache
    15:45:44.361 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'taxonomy_level-cache'.
    15:45:44.361 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'taxonomy_level-cache'.
    15:45:44.361 [http-nio-8080-exec-10] DEBUG net.sf.ehcache.Cache - Initialised cache: attribute_mapping-cache
    15:45:44.361 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured. Skipping for 'attribute_mapping-cache'.
    15:45:44.361 [http-nio-8080-exec-10] DEBUG n.s.e.config.ConfigurationHelper - CacheDecoratorFactory not configured for defaultCache. Skipping for 'attribute_mapping-cache'.
    15:45:44.363 [http-nio-8080-exec-10] DEBUG 46 - Decoration of object_ids-cache with ObjectIdsCache
    15:45:44.366 [http-nio-8080-exec-10] DEBUG c.e.d.dctm.web.services.D2fsContext - Session : s1 (0.166s)
    15:45:44.366 [http-nio-8080-exec-1] DEBUG c.e.d.dctm.web.services.D2fsContext - Session : s1 (0.166s)
    15:45:44.582 [http-nio-8080-exec-1] DEBUG c.e.d.dctm.web.services.D2fsContext - Release session : s1
    15:45:44.884 [http-nio-8080-exec-10] DEBUG 46 - dql : select r_object_id,upper(object_name),object_name,r_object_type,a_content_type,a_application_type,r_is_virtual_doc,r_link_cnt,r_lock_owner,r_policy_id,r_assembled_from_id,r_immutable_flag,r_frozen_flag,i_is_reference,title,r_modify_date,a_status,r_modifier from d2c_query_category where owner_name = USER and (folder('/Temp/Private searches') or folder('/Resources/mrcsd2crdmtseapprover/Private searches')) union select r_object_id,upper(object_name),object_name,r_object_type,a_content_type,a_application_type,r_is_virtual_doc,r_link_cnt,r_lock_owner,r_policy_id,r_assembled_from_id,r_immutable_flag,r_frozen_flag,i_is_reference,title,r_modify_date,a_status,r_modifier from d2c_query where owner_name = USER and (folder('/Temp') or folder('/Temp/Private searches') or folder('/Resources/mrcsd2crdmtseapprover/Private searches')) and object_name <> 'lastSearch' order by 2, 1
    15:45:44.959 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/D2-Widget-API-4.5.0.jar!/strings/bundles/DfTypeBundle_en.properties
    15:45:44.959 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/C6-Common-4.5.0.jar!/strings/bundles/DfTypeBundle_en.properties
    15:45:47.641 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/D2-Widget-API-4.5.0.jar!/strings/bundles/DfAttributeBundle_en.properties
    15:45:47.641 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/C6-Common-4.5.0.jar!/strings/bundles/DfAttributeBundle_en.properties
    15:45:47.991 [http-nio-8080-exec-4] DEBUG c.e.d.dctm.web.services.D2fsContext - Session : s1 (0.025s)
    15:45:47.992 [http-nio-8080-exec-4] DEBUG c.e.d.dctm.web.services.D2fsContext - Initializes admin session manager identity for MRCS_Dev
    15:45:48.043 [http-nio-8080-exec-4] DEBUG com.emc.d2.api.D2Session - ticket not found in cache - generate one
    15:45:48.570 [http-nio-8080-exec-4] DEBUG 40 - Start D2GetAdminTicketMethod method with JMS (Java Method Services)
    15:45:49.217 [http-nio-8080-exec-4] WARN  15 - No D2.lockbox found, error : com/emc/clb/LockBox
    15:45:49.266 [http-nio-8080-exec-4] DEBUG c.e.d.dctm.web.services.D2fsContext - Release session : s1
    15:45:50.132 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/C6-Common-4.5.0.jar!/strings/bundles/DfRelationBundle_en.properties
    15:45:51.029 [http-nio-8080-exec-10] DEBUG 46 - jar:file:/export/home1/jakarta/jakarta-tomcat-8.0.32_D2-RestService/webapps/d2fs-rest-web/WEB-INF/lib/C6-Common-4.5.0.jar!/strings/bundles/DfAuditBundle_en.properties
    15:45:51.038 [http-nio-8080-exec-10] DEBUG 46 - execute time : 6.154s
    15:45:51.050 [http-nio-8080-exec-10] INFO  org.dozer.config.GlobalSettings - Trying to find Dozer configuration file: dozer.properties
    15:45:51.055 [http-nio-8080-exec-10] WARN  org.dozer.config.GlobalSettings - Dozer configuration file not found: dozer.properties.  Using defaults for all Dozer global properties.
    15:45:51.058 [http-nio-8080-exec-10] INFO  org.dozer.DozerInitializer - Initializing Dozer. Version: 5.5.0, Thread Name: http-nio-8080-exec-10
    15:45:51.061 [http-nio-8080-exec-10] INFO  org.dozer.jmx.JMXPlatformImpl - Dozer JMX MBean [org.dozer.jmx:type=DozerStatisticsController] auto registered with the Platform MBean Server
    15:45:51.061 [http-nio-8080-exec-10] INFO  org.dozer.jmx.JMXPlatformImpl - Dozer JMX MBean [org.dozer.jmx:type=DozerAdminController] auto registered with the Platform MBean Server
    15:45:51.062 [http-nio-8080-exec-10] INFO  org.dozer.DozerBeanMapper - Initializing a new instance of dozer bean mapper.
    15:45:51.071 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.DozerResolver - Trying to resolve XML entity with public ID [null] and system ID [http://dozer.sourceforge.net/schema/beanmapping.xsd]
    15:45:51.071 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.DozerResolver - Trying to locate [beanmapping.xsd] in classpath
    15:45:51.071 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.DozerResolver - Found beanmapping XML Schema [http://dozer.sourceforge.net/schema/beanmapping.xsd] in classpath
    15:45:51.081 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - name: mapping
    15:45:51.082 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: class-a
    15:45:51.082 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: com.emc.d2fs.models.node.Node
    15:45:51.085 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: class-b
    15:45:51.085 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: com.emc.documentum.d2.rest.model.Node
    15:45:51.085 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: field
    15:45:51.089 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: a
    15:45:51.089 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: id
    15:45:51.089 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: b
    15:45:51.089 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: rObjectId
    15:45:51.089 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: field
    15:45:51.089 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: immutable
    15:45:51.089 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: children
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: children
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: field
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: a
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: attributes
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: b
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: nodeAttributes
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - name: mapping
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: class-a
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: com.emc.d2fs.models.attribute.Attribute
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: class-b
    15:45:51.090 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: com.emc.documentum.d2.rest.model.Attribute
    15:45:51.091 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: field
    15:45:51.091 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value:
    15:45:51.092 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser - config name: a
    15:45:51.092 [http-nio-8080-exec-10] DEBUG org.dozer.loader.xml.XMLParser -   value: isSearchable
    Hi Molarkr1,
    Rajeswar - thanks for the additional information.  Since standalone D2 and D2-Config work and problem specific to D2 REST in LEAP and it appears only D2GetAdminTicketMethod method.  We need to check and confirm if the following applies?:
    - The Lockbox password was changed on the JMS only or the D2 Method pass phrase is known to be different between the D2 Client and the JMS
    - Has the passphrase changed, at any time, in general?
    -Another cause of the problem might be mismatch between jars on CS and JMS, following support note gives details and worakround
    480867 : In D2 getting an error .java.lang.IllegalArgumentException: Invalid login ticket scope https://support.emc.com/kb/480867
    Please check the above let us know.
    Thanks. This is what Medtronic has to say about this error
    This is what Medtronic has to say about this error I am able to access the leap app, but not all functions are working. 1.      I am not able to view cabinet list 2.      I can see tasks but on approving gives an error 3.      Not able to run searches. We see the lockbox error only in D2-REST logs. and for my question So you can use D2 and D2-CONFIG without lock box errors and you don’t see the below problems, can you confirm? Yes. Just now tested again, able to approve the same task from D2, I was getting an error from LEAP app.
    I think any function that requires an admin ticket, for example auto link, might have this problem.  Can you check on passphrase changes from my earlier note?
    Can we have WebEx meeting  and  look into the issue ?
    Thanks
    Can you please send me an email and I'll arrange a meeting
    [email protected]
    Thanks.
    Recreated D2.lockbox on all 3 yesterday.
    1. D2 CS
    2. D2 Application server
    3. D2 Rest Services
    Thanks
    Molakr1,
    What was the outcome after recreation?  Did the problem go away?
