Aggregate values not appearing in excel
Best Answers
Found the issue. I had to uncheck the protected view options in excel. Now it works as expected.
1 -
@Eric Davis said:
Found the issue. I had to uncheck the protected view options in excel. Now it works as expected.To confirm why that is, when live formula's are enabled on export to Excel, aggregations typically will be an Excel formula instead of a static value. Protected view in Excel prevents formula's from calculating until you enable editing. If you were to disable live formula's, you'd see the aggregations without enabling editing.
@Chad Montgomery said:
Thanks for the explanation.
Answers
1 -
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
