ACL's in Documentum using DFC
1) download dfc javadocs. It has all the methods available to use and a lot of them have examples. Also, since your question is newbie question, I suggest you read Documentum Fundamentals guide as well.
2) if you want to ONLY assign user/group permit to one document, you can use IDfSysObject.grant(). if you want to re-use this ACL across multiple documents and folders, create system ACL and then assign the ACL to this document using IDfSysObject.setACLName() and setACLDomain()
3) To check if user/group is in ACL, look at the IDfACL.getAccessorName(). Keep in mind, you will have to check if user belongs to a group separately. Easier way to check if user has permissions on document is to use IDfSysObject.hasPermission().1
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
