how to setup Hardware (F5) load balancing for webtop 6.7 SP2
Hi Johnny,
Thanks for your quick response !
Is there any setting required for ucf content transfer at webtop end? Kindly suggest.Regards,
Ram0 -
Hi Johnny, Zhang,
While using the webtop application through F5 H/W load balancer, the page gets stuck at the downloading stage of documents and does not finish. Is there any settings need to do. Kindly suggest.
Regards,
Ram0 -
Typically if you are having problems with content transfer (ie editing, viewing, exporting, etc), this is issue with JRE installed on the browser and not an issue with load balancer. You can verify this by having the user go to IP address of app server directly and see if the issue persists.
- 107 Developer Announcements
- 53 Articles
- 106 General Questions
- 142 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 76 Digital Asset Management
- 118 Exstream
