How to view content of an object added using setFileEx
You don't. Webtop (and Documentum products in general) has limited support for multi-page documents. You would have to customize Webtop.
0 -
@bacham3 said:
You don't. Webtop (and Documentum products in general) has limited support for multi-page documents. You would have to customize Webtop.Thanks for your reply, can you also clarify if the way of adding multi pages(multi content objects) to a object is only through program i.e.., thru dfc custom code.
0 -
Some Documentum clients or partners products are capable of managing multi-page documents, although I'm not sure which ones. Documentum used to have a product called Image Viewer which supported multi-page documents. I suppose that Captiva provides some support for importing multi-page documents and perhaps Brava as well.
1
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
