username case sensitivity
I am looking for login component customization for username case sensitivity. I dont know how to do. Please help me
Thanks in advance
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
com.documentum.custom.formext.session.Login
/wdk/system/login/login.jspI have added above code for the login component.
Please let me know if any change require0 -
Checkout the Content Server Administration and Configuration Guide, Chapter 3 "Managing Documentum Servers". You can add the key user_auth_case to the server.ini file:
Specifies the case Documentum Server converts the user name of the client before authenticating the user. Valid values are:
• upper: The user name is converted to upper case.
• lower: The user name is converted to lower case.
• NULL: The default value. The name is authenticated using the case in which it was entered by the user.0 -
I have tried above changes but when we restart the Content Server it is failing. It is taking Administrator as administrator and it is trying to create session. It is telling that Authentication failed for the user 'administrator' and i was unable to restart the content server until i change the user_auth_case=NULL from lower. That's the reason why i went to customisation.
0 -
That's too bad. So I guess you'll have to go with a webtop customization.
Just as a side note, it's not recommended to install Documentum with the Windows Administrator account (just like to don't install it as root on Unix). Next time, create a dedicated account (e.g. dmadmin).
0 -
Hi bacham3,
I have created a component which extend login_component and add a new class which extent login class but itshowing me tomcat error
component code:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>com.documentum.custom.formext.session.login
Please check this code and let me know if i did any mistake
0 -
0 -
I dont know why but i am not able to post code here so attaching image
0 -
In com.documentum.web.formext.session folder .
0 -
I am following the content mentined in link :https://forums.opentext.com/forums/discussion/99698/login-username-case-insensitive-problem-class-file-not-calling-in-d6-5
Please let me if I miss any steps.
Thanks in advance0 -
Yes,
I have kept it in Custom.src.com.documentum.web.formext.session folder0
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
