Installed templating examples issues
I've installed the templating examples that are under /TeamSite/examples/Templating by copying directly to workingarea. However in the e-studio when i try to create a new content item only the content template yacht is in the options. All the others content templates are not available. Do you know what i am missing?
Best Regards and Thanks
OK,
i've updated the templating.cfg.
For instance for the press-realease content tenplate i have the following:
And now i can create a contentItem of press-release.
However, when i click in generate, i choose the template press-release.xsl, but the result of the page is empty with 0 bytes.
Note: the press-release.xsl is under templatedata/xml/press-release/presentation, should i put this path anywhere?
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
- Docker Automation
- TeamSite Add-ons
