IN DOCUMENT clause and a set function appear in the same SELECT."
HI all,
I want to sum the r_link_cnt from dm_document(all) in document_id ('r_object_id) descend.
select sum (r_link_cnt) from dm_document(all) in Document id('r_object_id') descend where r_link_cnt>=1;
getting error like Error occured during query execution :[DM_QUERY_E_COMPOUND_FUNC]error: "IN DOCUMENT clause and a set function appear in the same SELECT."
Is there any better way to get the sum of r_link_cnt.
Hello ,
Yes If i remove sum(), query is working fine. I am trying to count all the virtual documents with all descends including direct and indirect components.
0 -
If you see query, I am getting below result, my requirement is to get the sum of r_link_cnt as an end result. I.e 59 is the total sum.
select r_object_id,r_link_cnt from dm_document(all) in Document id(‘09001faa800b70e3’) descend where r_link_cnt>=1
r_object_id r_link_cnt
09001faa800be0e4 4
09001faa800b70e3 9
09001faa800b70e4 17
09001faa800b70e6 12
09001faa800b70e8 4
09001faa800b70ea 3
09001faa800b70ec 2
09001faa800b70ee 3
09001faa800b70f0 2
09001faa800b70f2 3
0 -
I'm not sure how summing up all r_link_cnt will be of much use. Remember that r_link_cnt represents the number of VD descendents + 1 (e.g. if you have 2 descendents it will be 3) and it will be 0 for leaf elements. With the where clause r_link_count >=1 you excluded all leaf elements.
Did you try it with a subselect: e.g. use your query as the inner query (dropping where clause) and the do an outer select where you filter the rows with r_link_cnt = 0 if that's what you want.
0 -
I tried like below
Dql--Enter Query:select sum (r_link_cnt) from dm_document(all) where r_object_id in
(select r_object_id from dm_document(all) in Document id('')descend
Execute Show the SQL
Error occured during query execution :[DM_QUERY_E_COMPOUND_SUB]error: "IN DOCUMENT clause appears within a subquery."but still getting the same error.? any help will be appreciated
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 144 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
