Error using POST method to send document to DCTM from SharePoint Online
Hi all,
I am trying to connect DCTM with SharePoint online and send single document using SPO flow. I am using REST API for it.
URI: dctm_path/rest/repositories/repository_name/folders/folder_id/documents
Followings are the parameters I am passing:
object: {"properties":{"r_object_type":"custon_object_type","object_name":"Test10","title":"Test10"}}
binary: test
content-type: application/vnd.emc.documentum+json;charset=UTF-8
While running the flow, I am getting following error:
"status": 400,
"code": "E_INPUT_MESSAGE_NOT_READABLE",
"message": "The input message is not readable.\r\nclientRequestId: 2fe2b792-56f0-4355-95a2-1787318768f4",
"details": "Required request body is missing: public com.emc.documentum.rest.model.DocumentObject com.emc.documentum.rest.controller.FolderChildDocumentsController.createChildDocument(java.lang.String,com.emc.documentum.rest.model.DocumentObject,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,int,boolean,com.emc.documentum.rest.http.UriInfo) throws com.documentum.fc.common.DfException,org.springframework.web.bind.MissingServletRequestParameterException",
"id": "2a47e10b-bd8e-4fce-a873-fd64a42b2503"
It seems that I am missing some parameter here. What can be the solution for it?
hi,
enclosed POJO which depends on rest-assured java library(https://mvnrepository.com/artifact/io.rest-assured/rest-assured/4.0.0) to trigger POST call to upload document into Documentum Server using dctm-rest APIimport io.restassured.response.Response;
import java.io.File;
import java.io.IOException;import static io.restassured.RestAssured.given;
public class DocumentImport {
private static String absoluteURL = "http://localhost:8181/dctm-rest/repositories/myRepo/folders/folder_r_object_id/documents";
private static Response response = null;
private static String userName = "c";
private static String userPassword = "c";
private static String fileName = "c:/temp/Sreecharan_Shroff.pdf";
private static String objectName = "{\"properties\":{\"object_name\":\"Sreecharan_Shroff.pdf\"}}";public static void main(String[] args) { try { documentImport(); System.out.println(response.asString()); } catch (IOException e) { e.printStackTrace(); } } public static void documentImport() throws IOException { response = given().multiPart("object", objectName) .multiPart("content", new File(fileName)).auth() .basic(userName, userPassword).when().post(absoluteURL); }
0 -
My issue was resolved when I send properties in body of request along with recommended Content-Type .
request({ method: 'POST', uri: 'http://(documentumservername)/repositories/usrel_tst/folders/(r_object_id)/documents', auth: { 'user': 'username', 'pass': 'password', 'sendImmediately': false }, headers: { "content-type": "application/vnd.emc.documentum+json", "format":"pdf" }, body: JSON.stringify( {"properties": {"object_name":"Test Doc 3.pdf", "r_object_type":"dm_document", "a_content_type":"pdf"}}) }, function (error, response, body) { if (error) { return console.error('upload failed:', error); } console.log('Response Body:', body); })
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
