CI/CD for Documentum xCP
HI all,
We are planning on using Jenkins as the orchestrator for automating the overall Documentum xCP deployments ( configuration).
Also, we are intending to use Nexus 3 for storing artifacts and utilising native xCP maven to build and packaging and xDP for doing the deployment.
Is there a preferred set of DevOps toolset for Documentum xCP
Also, is there an easy way to invoke the build packaging ( which is normally done through the IDE) from Jenkins directly
Kind Regards
Shan
Have you looked at this:
1 -
Application created in xCP is basically a maven project.
So, in Jenkins, you can use maven commands to do cli import, package, deploy to target environments.
No need of any external dependencies/plugins.1 -
@NaShan said:
Great.. Thanks Charan..
Are there any samples of the maven commands to do cli import, package and deploy you can share..few examples:
8. Run the mvn xcp-import-project:run command to import projects to your local machine.
9. Navigate to the newly created POM file at command prompt and run the following command:
mvn install "-DdesignerPath="
Maven creates .WAR and .config.xml files for the application created using xCP Designer.please refer to page 476 in
OpenText™ Documentum™ xCelerated Composition Platform Designer Help 16.4.1 User Guide.pdf1 -
@NaShan said:
Yes while searching, did find this yesterday.
This was when xMS was there but now we have xCP with xDA, how can this be achieved...Last time I checked, xDA was just a "renamed" xMS with some additional logic, all the classes from xMS are there and it's what xDA uses, so it should work (or be easily adaptable)
1 -
@AlvaroDeAndresGomez Thank you. We will make an attempt at this shortly and will come back in case of any more queries.
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
