Error while executing custom method.
While I was trying to run my custom method in java.I'm getting the below error message in the server log.
Here is my java program:
**package com.verinon;
import java.io.PrintWriter;
import java.util.Map;
import com.documentum.fc.common.DfLogger;
import com.documentum.fc.methodserver.IDfMethod;
public class Custom_Method_Test implements IDfMethod {
@Override public int execute(Map arg0, PrintWriter arg1) throws Exception { // TODO Auto-generated method stub DfLogger.info(this, "Custom job is created successfuly", null, null); return 0; }
Error message in the log file is stated below (log file path:C:\Documentum\wildfly9.0.1\server\DctmServer_MethodServer\log):
019-07-19 10:11:15,655 ERROR [320] (default task-25) {}: java.lang.ClassCastException: org.slf4j.impl.Slf4jLoggerFactory cannot be cast to ch.qos.logback.classic.LoggerContext
at com.emc.common.dctm.logs.C6Logger.activateJMSLog(C6Logger.java:187)
at com.emc.d2.api.methods.D2Method.execute(D2Method.java:1285)
at com.documentum.mthdservlet.DfMethodRunner.runIt(Unknown Source)
at com.documentum.mthdservlet.AMethodRunner.runAndReturnStatus(Unknown Source)
at com.documentum.mthdservlet.DoMethod.invokeMethod(Unknown Source)
at com.documentum.mthdservlet.DoMethod.doPost(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:86)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:58)
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:72)
at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.security.handlers.SecurityInitialHandler.handleRequest(SecurityInitialHandler.java:76)
at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:282)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:261)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:80)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:172)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:199)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:774)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Can anyone help me with this?
Ganesh.
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 900 Cloud Fax and Notifications
- 120 Exstream
