Error accessing D2 Config "CTX ActiveX control failed to load. Please check browser secure settings"
Hello to all,
I'm going crazy with this problem.
I thought I had solved it in the past but ... today it seems that in my small group my PC is the only one with which it is possible to connect to D2 Config.
All my colleagues' PCs have the exact same problem, and they all use the same version of Windows Pro 10 and IE 11 that I use.
I also tried a VM with Windows Server 2012 and IE11, so as not to destroy my PC with tests, but I can't find a solution.
The D2 site is inserted between "trusted", the security settings are the widest possible with respect to ActiveX controls and ActiveX filtering is activated (deactivating does not changes the effect).
D2 is 4.7.0160 build 454 with D2 ActiveX 3.1.0.4.
What could still be missing?
Thanks in advance for any suggestions.
Arthy
Same problem here, really interested in a solution.
In my case:
- D2 is 16.5.1000 build 0055
- D2 ActiveX is 16.6.0.1
- Site is into "Local Intranet"
- Security settings are the widest possible with respect to ActiveX controls
Other colleagues with same settings connect correctly to the system.
Thanks
Marco0 -
Ensure that VC++ 2008 runtime is installed on the machine:
Samir Vaidya
Enterprise Software Architect
OpenText0 -
@s_vaidya said:
Only thing I need to do any any new system is to add D2-Config URL in "trusted sites" list and ensure that VC++ 2008 runtime is installed.It worked for me also, thank you!
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
