How to pass parameters to case model in AppWorks
If you are new to AppWorks, then you probably should not be using the case model. You should be able to implement most patterns using either the Lifecycle Building Block or the Business Process Model.
0 -
Entity item information (Item ID) will be available as a property (rootEntityInstanceId) of the process instance in the business
process. You can use the Read Web Service to get information from the referring Entity.1
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
