Custom CSV emitter not working while Running but working in Debug mode
We built a custom CSV emitter (as per shared code on Google) and deployed the generated CSV emitter plugin jar in BIRT Desktop Designer 4.4. Run as CSV option is coming when we try to run a report from Desktop Designer, the CSV report is getting generated without any data. There are no error logs for the same. But when we debug the CSV report, it is working as expected and generating CSV with all the data.
Also, when we deployed the same plugin in BIRT server and run a report through our application UI, we are getting the following error. PFA BIRT server error logs
[Thread 38] 2019-11-13 15:09:31 UTC+0000 com.actuate.javaserver.soap.ActuateSoapBindingImpl.logException()
WARNING: The conversion from "rptdesign" to "csv" is not supported.com.actuate.reportapi.enginemanager.JREMException: The conversion from "rptdesign" to "csv" is not supported.
at com.actuate.reportapi.engine.birt.GetDocumentConversionOptionsTask.checkAndAddConversionOptions(GetDocumentConversionOptionsTask.java:202)
Has someone faced the same issue? Kindly help and share your suggestion(s) / resolution(s). Thanks in advance.
Why build your own when this one works fine. I've never had an issue with it.
https://forums.opentext.com/forums/discussion/61207/csv-emitter-plugin-for-birt
- 108 Developer Announcements
- 53 Articles
- 107 General Questions
- 144 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 119 Exstream
