LiveSite Publish workflow issue
Recent fresh install of 16.6.0.0 and working on the setup. When initiating Livesite Publish workflow, on Submit of the workflow. we get "HTTP method POST is not supported by this URL ". The URL of the workflow screen at that point is, http:///iw-cc/Workflow/WebTask.do
Thought this might be a max post size issue so added "max-post-size="104857600" to /apps/interwoven/ApplicationContainer/standalone/configuration/standalone.xml
<http-listener name="default" tcp-keep-alive="true" read-timeout="30000" socket-binding="http" redirect-socket="https" enable-http2="true" max-post-size="104857600"/>
Appreciate any suggestions. Thanks!
Found the answer
Teamsite - Impact of struts removal on WebTask component
https://knowledge.opentext.com/knowledge/cs.dll/kcs/kbarticle/view/KB13552765Note the comment at the bottom of this this KB for final and correct answer.
- 108 Developer Announcements
- 53 Articles
- 107 General Questions
- 144 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 119 Exstream
TeamSite Developer Resources
- Docker Automation
- TeamSite Add-ons
