Implementing ICommand using C# and registering command
Hello all,
Trying to create a custom command by implementing IManExt.ICommand using C#.
And I have added registry entries for the custom command. But still I can not see my custom command.
I have registred my dll using GAC util to move it to assembly cache.
Can any one suggest what I am missing.
Naresh
  • Did you build it as a COM visable dll and register it with regsvr32?
  • Hello all,
    Naresh
    Hi Naresh,
    We are also working on a custom code integration which is using IMANEXTLib.
    Being new to worksite and Dot net environment, I am getting difficulty to locate the library to include in my project.
    Can you please guide me with the location of IMANEXTLib.DLL ?
    Appreciate your help.
    Amit
  • On a 64bit machine with File site or Desksite 8.5 installed should be in
    C:\Program Files (x86)\Interwoven\WorkSite
    for a 32 bit
    C:\Program Files\Interwoven\WorkSite
    This dll is a COM dll, and should appear as IManExt 1.0 type library in the list of com references
    Hope this helps
TeamSite Developer Resources
  • Docker Automation
  • LiveSite Content Services (LSCS) REST API
  • Single Page Application (SPA) Modules
  • TeamSite Add-ons
OpenText CE Products
TeamSite
APIs
