How create custom triggers ?
Hi ,
I am trying to create custom triggers and gone through pdf for the same. I have few doubts .
1-If I need to have trigger on dcr save or new file creation then how we hv to register iwatcreate in iwlocal.cfg.
2-How we can set env. variables for it that are req. before prog. execution.
Thanks
The iwat trigger is a very low level feature that has performance impacts, and it's difficult to get working correctly especially if you don't know what you're doing. Consider this approach a last resort. Instead, try catching the onSave event in the form, or clarify your requirement if that's not sufficient.
Also note that you can't set environment vars in your iwat script. It would have to pull values from elsewhere.
0 -
Also, please don't cross post because then this happens.
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
- Docker Automation
- TeamSite Add-ons
